주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
해당 분해도는 수리 안내서가 아닙니다. Tile Sticker 수리는 자사의 서비스 설명서를 사용하세요.
  1. Tile Sticker Teardown, Tile Sticker Teardown: 1 단계, 이미지 1개 중 1개
    • Use a spudger or flathead screwdriver to remove the outer ring
    • I removed the rubber button cover as well, but this is not necessary.
  2. Tile Sticker Teardown: 2 단계, 이미지 1개 중 1개
    • Use a flathead screwdriver to pry the two halves of the case apart from each other
    • The technique I used is to find a small hole in the casing and use a very small flathead screwdriver with upward/downward force.
  3. Tile Sticker Teardown: 3 단계, 이미지 1개 중 1개
    • Pull the electronics out of the casing.
  4. Tile Sticker Teardown: 4 단계, 이미지 1개 중 1개
    • At the bottom is the power source - A soldered-in CR2032 battery.
  5. Tile Sticker Teardown: 5 단계, 이미지 1개 중 1개
    • Hidden away in the top casing is a piezoelectric speaker.
  6. Tile Sticker Teardown: 6 단계, 이미지 1개 중 1개
    • The main chips:
    • 240 C29
    • N(RF)52810 CAAAD0 1928AE
작성자
1다른 기여자 명과 함께
Andrew S
회원 가입일: 07/30/21
15,469 평판
안내서 8개를 작성함
8가이드 댓글
I’m glad I was not the only one who tried this, but you had much more success than me. We used to use ours for the remote to the TV which gets lost often and then the battery died and I refused to believe it was not user replaceable. Unfortunately I didn’t have much luck actually getting past step 1 since the two halves staunchly refused to come apart. So I murdered it in frustration and threw it in the bin.
Alisha C - 답글 공유
Yep, mine lasted a little less than 2 years. The key to getting the two casing halves apart is to use a really small flathead screwdriver and put it in one of the holes in the casing, then start pushing downwards.
Andrew S - 공유
So I got it open, desoldered the battery, resoldered a new one - and it turns on and beeps with a double tap… doesn’t ack its location, can’t be dinged from the app… can’t activate it because it says it’s already activated (duh) - but it’s been off for > 760 days according to Tile. Pretty sure they have a “drop dead” condition or some ultimate expiration date on the ones with soldered batteries (this forcing you to get new ones). AirTags for me from now on (I just wish they were louder)
Dave Miller - 답글 공유
Scratch that! After repeatedly clicking - it’s now working again… huzzah!
Dave Miller - 답글 공유
Glad to hear you had success in replacing the battery inside your Tile Sticker!
Andrew S - 공유
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 35
지난 30일: 195
전체 시간: 11,155
