주요 콘텐츠로 건너뛰기
Timbuk2 Messenger Bag 1" Front Male Clip Replacement
필요한 것
  1. Timbuk2 Messenger Bag 1" Front Male Clip Replacement, 1" Front Male Clip: 1 단계, 이미지 1/2 Timbuk2 Messenger Bag 1" Front Male Clip Replacement, 1" Front Male Clip: 1 단계, 이미지 2/2
    • Does your front male clip look like this? Follow these easy steps to get your messenger bag back up to fighting shape!
    • Here are the things you'll need:
    • You'll need a new male clip. Get it here!
    • Wire cutters or heavy duty scissors.
  2. Timbuk2 Messenger Bag 1" Front Male Clip Replacement: 2 단계, 이미지 1/3 Timbuk2 Messenger Bag 1" Front Male Clip Replacement: 2 단계, 이미지 2/3 Timbuk2 Messenger Bag 1" Front Male Clip Replacement: 2 단계, 이미지 3/3
    • Using wire cutters or heavy duty scissors, break off old male clip and remove from fabric.
    • Insert scissors in the space between the strap and the buckle's first loop and cut through. Next, insert scissors in second loop between the strap and the buckle's second loop and cut through. (It is easier to cut on the inside edges of the loops than to cut the loops in the center)
  3. Timbuk2 Messenger Bag 1" Front Male Clip Replacement: 3 단계, 이미지 1/1
    • This is where your new male clip will come in handy.
  4. Timbuk2 Messenger Bag 1" Front Male Clip Replacement: 4 단계, 이미지 1/3 Timbuk2 Messenger Bag 1" Front Male Clip Replacement: 4 단계, 이미지 2/3 Timbuk2 Messenger Bag 1" Front Male Clip Replacement: 4 단계, 이미지 3/3
    • Insert new 1 inch male buckle in existing female buckle.
    • Take strap and insert it from the back side of the buckle, through the top loop.
    • Next, insert the rest of the strap through the bottom loop and pull though.
  5. Timbuk2 Messenger Bag 1" Front Male Clip Replacement: 5 단계, 이미지 1/1
    • You're all done!
결승점
다른 5명이 해당 안내서를 완성하였습니다.
Emilee
회원 가입일: 03/13/14
1,591 평판
안내서 9개 작성하였습니다
댓글 6개
Thanks for this guide! I tried pulling the strap through the old clip and it wouldn't go through, so I thought I had to cut and re-sew the ends. I am so glad I saw this, saved me a lot of work! Thanks again!
Phone Person - 답글
Thank you so much for this! My pup chewed the clip off of my bag less than two weeks after purchase. I was bummed. Went to the Timbuk2 site and all these reviews said I had to cut and resew the ends…. I KNEW there had to be a better way. Took me less than 5 minutes. Thank you, Thank you, Thank you!!!
wmc - 답글
Oof. This didn’t work at all, unfortunately. The strap doesn’t fit through the new buckle. I ended up having to cut and resew the ends.
Chris Denzer - 답글
Seems impossible to get the bulky Timbuk2 logo through the second opening of the buckle when looping. Anyone have any tips or tricks?
srapture - 답글
I wasn’t able to get the strap through my new clip either, the reflector piece is just too thick for it. I took a Dremel to the new clip and cut a notch out of the center piece of plastic (that the strap goes around) so i could feed the folded strap through. It works as good as new and you can’t see the notch cut out because the strap covers it up.
Brady Dahl - 답글
had to muscle it through the clip with pliers. Was not easy, but got it done.
Stephen Crane - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 61
전체 시간: 11,293
