주요 콘텐츠로 건너뛰기
Timbuk2 Messenger Bag Male Cambuckle Replacement
필요한 것
  1. Timbuk2 Messenger Bag Male Cambuckle Replacement, Male Cambuckle: 1 단계, 이미지 1/3 Timbuk2 Messenger Bag Male Cambuckle Replacement, Male Cambuckle: 1 단계, 이미지 2/3 Timbuk2 Messenger Bag Male Cambuckle Replacement, Male Cambuckle: 1 단계, 이미지 3/3
  2. Timbuk2 Messenger Bag Male Cambuckle Replacement: 2 단계, 이미지 1/3 Timbuk2 Messenger Bag Male Cambuckle Replacement: 2 단계, 이미지 2/3 Timbuk2 Messenger Bag Male Cambuckle Replacement: 2 단계, 이미지 3/3
    • Remove broken cam buckle. Un-thread strap from bottom plastic loop and take strap off.
  3. Timbuk2 Messenger Bag Male Cambuckle Replacement: 3 단계, 이미지 1/3 Timbuk2 Messenger Bag Male Cambuckle Replacement: 3 단계, 이미지 2/3 Timbuk2 Messenger Bag Male Cambuckle Replacement: 3 단계, 이미지 3/3
    • Thread strap into new cam buckle through the buckle's top opening. Pull strap through the bottom of the buckle, ensuring that the strap goes in FRONT of the connectors as shown.
    • Make sure the strap is not twisted or facing the wrong way when inserting the new cambuckle!
  4. Timbuk2 Messenger Bag Male Cambuckle Replacement: 4 단계, 이미지 1/1
    • Snap buckle into female cam buckle and close the buckle.
  5. Timbuk2 Messenger Bag Male Cambuckle Replacement: 5 단계, 이미지 1/2 Timbuk2 Messenger Bag Male Cambuckle Replacement: 5 단계, 이미지 2/2
    • Thread strap through the bottom of the plastic loop (the loop where the strap was thread though before).
    • Next, thread end of strap through the top end of plastic loop and pull to desired length.
  6. Timbuk2 Messenger Bag Male Cambuckle Replacement: 6 단계, 이미지 1/1
    • Congrats! You're all done!
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Emilee
회원 가입일: 03/13/14
1,591 평판
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 7
전체 시간: 3,757
