주요 콘텐츠로 건너뛰기
Timbuk2 Pannier Bottom Stay Bracket Replacement
필요한 것
  1. Timbuk2 Pannier Bottom Stay Bracket Replacement, Bottom Stay Bracket: 1 단계, 이미지 1개 중 1개
    • Tools needed:
    • New Pannier Bottom Stay Bracket.
    • Standard Screwdriver
    • Wrench
  2. Timbuk2 Pannier Bottom Stay Bracket Replacement: 2 단계, 이미지 2개 중 1개 Timbuk2 Pannier Bottom Stay Bracket Replacement: 2 단계, 이미지 2개 중 2개
    • To remove bottom stay bracket, first unscrew all 4 screws. To do so, undo velcro flap located at the top of the laptop sleeve. With the wrench, hold nut in place in the back of the pannier, while using the screwdriver to unscrew the screw in the front bracket.
  3. Timbuk2 Pannier Bottom Stay Bracket Replacement: 3 단계, 이미지 1개 중 1개
    • Remove old clip. Take new bottom bracket and remove all screws and washers from bracket (Make sure to put all screws, washers, and nuts in a safe place (Ziploc bag) as to not lose any!)
    • Follow step 2 in reverse order to attach new clip bracket. (Hold nut with wrench while screwing back in place. Also make sure the washers are between the screws and the body of the bag.)
  4. Timbuk2 Pannier Bottom Stay Bracket Replacement: 4 단계, 이미지 1개 중 1개
    • All Done!
결승점
Emilee
회원 가입일: 03/13/14
1,621 평판
안내서 9개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 408
