주요 콘텐츠로 건너뛰기
Timbuk2 Pannier Whole Clip Bracket Replacement
필요한 것
  1. Timbuk2 Pannier Whole Clip Bracket Replacement, Whole Clip Bracket: 1 단계, 이미지 1개 중 1개
    • Here are the tools you will need:
    • Standard Screwdriver
    • New Pannier Whole Clip Bracket
    • Wrench
  2. Timbuk2 Pannier Whole Clip Bracket Replacement: 2 단계, 이미지 1개 중 1개
    • To remove clip bracket, first remove all 3 clips using the #2 screwdriver or hand drill (Make sure to put clips and their screws and anchor plates in a safe place as to not misplace any such as a Ziploc bag).
  3. Timbuk2 Pannier Whole Clip Bracket Replacement: 3 단계, 이미지 1개 중 1개
    • Unscrew all 13 small black screws. To do so, undo velcro flap located at the top of the laptop sleeve. With the wrench, hold nut in place in the back of the pannier.
  4. Timbuk2 Pannier Whole Clip Bracket Replacement: 4 단계, 이미지 1개 중 1개
    • While holding nuts with the wrench, use the screwdriver to unscrew the screw in the front bracket.
  5. Timbuk2 Pannier Whole Clip Bracket Replacement: 5 단계, 이미지 2개 중 1개 Timbuk2 Pannier Whole Clip Bracket Replacement: 5 단계, 이미지 2개 중 2개
    • Remove old clip. Take new clip bracket and unscrew and remove middle clip.
  6. Timbuk2 Pannier Whole Clip Bracket Replacement: 6 단계, 이미지 1개 중 1개
    • Replace the middle clip and screw it into place on the bag. Place the new clip bracket in place and screw in all 13 screws again.
    • As in step 3 and 4, hold nut with wrench while screwing clip in place. (Be sure to keep washers in between the screws and the body of the bag)
  7. Timbuk2 Pannier Whole Clip Bracket Replacement: 7 단계, 이미지 1개 중 1개
    • You're done!
결승점
Emilee
회원 가입일: 03/13/14
1,621 평판
안내서 9개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 1,289
