주요 콘텐츠로 건너뛰기
Timex Ironman Triathlon Battery Replacement
필요한 것
  1. Timex Ironman Triathlon Battery Replacement, Remove Strap From: 1 단계, 이미지 3개 중 1개 Timex Ironman Triathlon Battery Replacement, Remove Strap From: 1 단계, 이미지 3개 중 2개 Timex Ironman Triathlon Battery Replacement, Remove Strap From: 1 단계, 이미지 3개 중 3개
    • Use small flat tool such as a Flathead screwdriver to press the metal "spring bars" inward, one at a time, to release the wrist-band from the "Lugs."
    • Repeat first step on opposite side.
  2. Timex Ironman Triathlon Battery Replacement, Removing Backplate: 2 단계, 이미지 3개 중 1개 Timex Ironman Triathlon Battery Replacement, Removing Backplate: 2 단계, 이미지 3개 중 2개 Timex Ironman Triathlon Battery Replacement, Removing Backplate: 2 단계, 이미지 3개 중 3개
    • Remove screws the 4 screws using #000 Philips Bit.
    • Carefully remove back-plate, and lay it on its back.
  3. Timex Ironman Triathlon Battery Replacement, Removing Contact-Plate: 3 단계, 이미지 3개 중 1개 Timex Ironman Triathlon Battery Replacement, Removing Contact-Plate: 3 단계, 이미지 3개 중 2개 Timex Ironman Triathlon Battery Replacement, Removing Contact-Plate: 3 단계, 이미지 3개 중 3개
    • Use JIS #000 Bit to unscrew the screw that secures the 2025 coin-cell battery underneath the white sticker.
    • Remove the screw from the eyelet, and place it to the side in a safe place.
  4. Timex Ironman Triathlon Battery Replacement: 4 단계, 이미지 3개 중 1개 Timex Ironman Triathlon Battery Replacement: 4 단계, 이미지 3개 중 2개 Timex Ironman Triathlon Battery Replacement: 4 단계, 이미지 3개 중 3개
    • Carefully lift contact-bracket up and peel dead battery off, for recycling.
    • Unlatch the empty contact-bracket by gently lifting the bracket up, off, and away from the plastic knuckle that is holding it onto the body of the watch.
    • Place contact-bracket face-up on a secure surface.
    • Place the positive(+) side of the new battery facing down on the contact-bracket.
  5. Timex Ironman Triathlon Battery Replacement, Secure New Battery: 5 단계, 이미지 2개 중 1개 Timex Ironman Triathlon Battery Replacement, Secure New Battery: 5 단계, 이미지 2개 중 2개
    • Carefully replace contact-bracket by hanging the metal latch over the plastic knuckle.
    • Tighten screw.
    • Reset system settings by touching both gold pins with a conductive tool, such as the tip of a small Flathead screwdriver, or tweezers.
  6. Timex Ironman Triathlon Battery Replacement, Secure Back-Plate: 6 단계, 이미지 3개 중 1개 Timex Ironman Triathlon Battery Replacement, Secure Back-Plate: 6 단계, 이미지 3개 중 2개 Timex Ironman Triathlon Battery Replacement, Secure Back-Plate: 6 단계, 이미지 3개 중 3개
    • Replace back-plate with logo facing same orientation as watch-face.
    • Replace and tighten screws from Step 2 with Bit #000, starting diagonally to create maximum water-resistance.
결론
To reassemble your device, follow these steps in reverse, but remember to replace screws in a diagonal order to create a tight seal, and improve water-resistance.
작성자
1다른 기여자 명과 함께
Phoenixwa
회원 가입일: 03/16/22
193 평판
안내서 2개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 31
지난 30일: 81
전체 시간: 283
