주요 콘텐츠로 건너뛰기
Timex W-10 Children's Watch Battery Replacement
필요한 것
  1. Timex W-10 Children's Watch Battery Replacement, Battery: 1 단계, 이미지 1/3 Timex W-10 Children's Watch Battery Replacement, Battery: 1 단계, 이미지 2/3 Timex W-10 Children's Watch Battery Replacement, Battery: 1 단계, 이미지 3/3
    • Pull on the watch strap through the top of the strap buckle to unlock the strap.
  2. Timex W-10 Children's Watch Battery Replacement: 2 단계, 이미지 1/2 Timex W-10 Children's Watch Battery Replacement: 2 단계, 이미지 2/2
    • Once the strap has been unlocked, hold onto the strap buckle and pull away from the watch to completely remove the band.
  3. Timex W-10 Children's Watch Battery Replacement: 3 단계, 이미지 1/2 Timex W-10 Children's Watch Battery Replacement: 3 단계, 이미지 2/2
    • Use the PH00 screwdriver to remove the four screws from each corner of the rear metal cover.
  4. Timex W-10 Children's Watch Battery Replacement: 4 단계, 이미지 1/2 Timex W-10 Children's Watch Battery Replacement: 4 단계, 이미지 2/2
    • Gently remove the back plate to expose the battery.
  5. Timex W-10 Children's Watch Battery Replacement: 5 단계, 이미지 1/2 Timex W-10 Children's Watch Battery Replacement: 5 단계, 이미지 2/2
    • The battery spring will propel the battery upward as soon as the base cover is removed. Be sure to place the battery in a safe spot.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Tarik Ihmoud
회원 가입일: 02/28/17
128 평판
안내서 1개 작성함
University of Memphis, Team S4-G2, Baddour Spring 2017 University of Memphis, Team S4-G2, Baddour Spring 2017 회원
UM-BADDOUR-S17S4G2
2 회원들
안내서 1개 작성하였습니다
댓글 2개
I'm looking for an adult Timex watch battery replacement that has a metal watch band.
Daniel Melendrez - 답글
Daniel Melendrez - June 12
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 12
30일 전: 78
전체 시간: 8,091
