주요 콘텐츠로 건너뛰기
Tineco FLOOR ONE S3 Breeze Motherboard Replacement
필요한 것
  1. Tineco FLOOR ONE S3 Breeze Motherboard Replacement, Battery: 1 단계, 이미지 1/2 Tineco FLOOR ONE S3 Breeze Motherboard Replacement, Battery: 1 단계, 이미지 2/2
    • Remove six 10.6 mm screws from the back of the vacuum with a Phillips #1 screwdriver.
    • Remove the entire back piece.
  2. Tineco FLOOR ONE S3 Breeze Motherboard Replacement: 2 단계, 이미지 1/1
    • Remove four 10.6 mm screws from the remaining white back piece with a Phillips #1 screwdriver.
  3. Tineco FLOOR ONE S3 Breeze Motherboard Replacement: 3 단계, 이미지 1/3 Tineco FLOOR ONE S3 Breeze Motherboard Replacement: 3 단계, 이미지 2/3 Tineco FLOOR ONE S3 Breeze Motherboard Replacement: 3 단계, 이미지 3/3
    • Pry open and remove the black ring at the top of the vacuum using by using an opening tool.
    • Remove four 10.6 mm screws located underneath the previously pried ring using a Phillips #1 screwdriver.
    • Remove the top circular piece from the body of the vacuum.
  4. Tineco FLOOR ONE S3 Breeze Motherboard Replacement: 4 단계, 이미지 1/1
    • Remove the white back piece of the vacuum.
  5. Tineco FLOOR ONE S3 Breeze Motherboard Replacement: 5 단계, 이미지 1/2 Tineco FLOOR ONE S3 Breeze Motherboard Replacement: 5 단계, 이미지 2/2
    • Unplug the wires of the battery by carefully pulling them up from the motherboard.
    • Slide the battery out of its slot and replace it with the new battery.
    • The connection may be difficult to remove. Be careful not to rip the entire connector from the motherboard.
  6. Tineco FLOOR ONE S3 Breeze Motherboard Replacement, Motherboard: 6 단계, 이미지 1/1
    • Carefully remove all the wire connections from the motherboard.
    • Take note of where and how the wires were connected, so they can be rewired to the new motherboard.
  7. Tineco FLOOR ONE S3 Breeze Motherboard Replacement: 7 단계, 이미지 1/2 Tineco FLOOR ONE S3 Breeze Motherboard Replacement: 7 단계, 이미지 2/2
    • Remove the four 10.6 mm screws holding the motherboard using a Phillips #1 screwdriver.
    • Carefully remove the motherboard from the vacuum.
결론
Dawoud Daoud
회원 가입일: 02/14/24
199 평판
안내서 2개 작성하였습니다
University of Memphis, Team 3-5, Sneed Spring 2024 University of Memphis, Team 3-5, Sneed Spring 2024 회원
UM-SNEED-S24S3G5
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 7
30일 전: 25
전체 시간: 69
