주요 콘텐츠로 건너뛰기
Tineco FLOOR ONE S3 Breeze Motor Replacement
필요한 것
  1. Tineco FLOOR ONE S3 Breeze Motor Replacement, Wheels: 1 단계, 이미지 1/2 Tineco FLOOR ONE S3 Breeze Motor Replacement, Wheels: 1 단계, 이미지 2/2
    • Remove four 10.6 mm screws from the plastic cover with a Phillips #1 screwdriver.
    • Remove the first plastic cover.
  2. Tineco FLOOR ONE S3 Breeze Motor Replacement: 2 단계, 이미지 1/2 Tineco FLOOR ONE S3 Breeze Motor Replacement: 2 단계, 이미지 2/2
    • Remove twelve 10.6 mm screws from the second plastic cover with a Phillips #1 screwdriver.
    • Remove the second plastic cover.
  3. Tineco FLOOR ONE S3 Breeze Motor Replacement: 3 단계, 이미지 1/2 Tineco FLOOR ONE S3 Breeze Motor Replacement: 3 단계, 이미지 2/2
    • Remove two 10.6 mm screws holding the wheels in place with a Phillips #1 screwdriver.
    • Remove the wheels.
    • The wheels do not need to be removed to access the motor.
  4. Tineco FLOOR ONE S3 Breeze Motor Replacement, Motor: 4 단계, 이미지 1/1
    • Remove the motor and the brush arm.
  5. Tineco FLOOR ONE S3 Breeze Motor Replacement: 5 단계, 이미지 1/1
    • Remove three 10.56 mm screws from the gear with a Phillips #1 screwdriver.
  6. Tineco FLOOR ONE S3 Breeze Motor Replacement: 6 단계, 이미지 1/1
    • Simply pull by the base of wires to remove them from the motor.
    • Remove the gear from the brush arm.
결론
Luke Guess
회원 가입일: 02/14/24
193 평판
안내서 2개 작성하였습니다
University of Memphis, Team 3-5, Sneed Spring 2024 University of Memphis, Team 3-5, Sneed Spring 2024 회원
UM-SNEED-S24S3G5
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 14
30일 전: 62
전체 시간: 121
