주요 콘텐츠로 건너뛰기
Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement
필요한 것
  1. Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement, Safety precautions: 1 단계, 이미지 1/2 Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement, Safety precautions: 1 단계, 이미지 2/2
    • Before you begin, make sure to follow the pressure relief procedure documented in the user manual before powering down the paint sprayer and disconnecting the pump.
    • Turn off and unplug the sprayer.
  2. Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement, Remove the valve handle: 2 단계, 이미지 1/3 Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement, Remove the valve handle: 2 단계, 이미지 2/3 Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement, Remove the valve handle: 2 단계, 이미지 3/3
    • Use a flat punch tool and a hammer to tap the groove pin from left to right out of the valve handle.
  3. Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement: 3 단계, 이미지 1/2 Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement: 3 단계, 이미지 2/2
    • Remove the valve handle from the cam base.
    • During reassembly, apply grease to the cam base before reattaching the valve handle.
  4. Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement, Remove the cam base: 4 단계, 이미지 1/3 Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement, Remove the cam base: 4 단계, 이미지 2/3 Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement, Remove the cam base: 4 단계, 이미지 3/3
    • Remove the cam base.
  5. Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement, Loosen the bypass valve assembly: 5 단계, 이미지 1/2 Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement, Loosen the bypass valve assembly: 5 단계, 이미지 2/2
    • Use a 13/16" wrench, or an adjustable wrench, to loosen the bypass valve assembly.
    • Rotate the wrench counterclockwise.
  6. Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement, Remove the bypass valve assembly: 6 단계, 이미지 1/2 Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement, Remove the bypass valve assembly: 6 단계, 이미지 2/2
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Alex Diaz-Kokaisl
회원 가입일: 01/16/22
124,996 평판
안내서 582개 작성하였습니다
iFixit iFixit 회원
Staff
136 회원들
안내서 17,410개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 6
30일 전: 27
전체 시간: 484
