주요 콘텐츠로 건너뛰기
Titan Airless Sprayer IMPACT 410 Capacitor Replacement
필요한 것
  1. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Safety precautions: 1 단계, 이미지 1/2 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Safety precautions: 1 단계, 이미지 2/2
    • Before you begin, make sure to follow the pressure relief procedure documented in the user manual before powering down the paint sprayer and disconnecting the pump.
    • Turn off and unplug the sprayer.
  2. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Unfasten the motor cover: 2 단계, 이미지 1/2 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Unfasten the motor cover: 2 단계, 이미지 2/2
    • Use a Phillips driver to remove the four 12 mm-long screws (two on either side) securing the motor cover.
  3. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Remove the motor cover: 3 단계, 이미지 1/3 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Remove the motor cover: 3 단계, 이미지 2/3 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Remove the motor cover: 3 단계, 이미지 3/3
    • Pull the motor cover straight off the motor.
  4. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Isolate the capacitor wires: 4 단계, 이미지 1/3 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Isolate the capacitor wires: 4 단계, 이미지 2/3 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Isolate the capacitor wires: 4 단계, 이미지 3/3
    • Use diagonal cutters, or scissors, to cut the two cable ties bundling the capacitor's positive and negative wires.
    • During reassembly, replace the cable ties.
  5. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Disconnect the negative wire: 5 단계, 이미지 1/2 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Disconnect the negative wire: 5 단계, 이미지 2/2
    • Disconnect the black negative wire's spade connector.
    • Always grip cables by their connectors and not the wires themselves.
  6. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Disconnect the positive wire: 6 단계, 이미지 1/2 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Disconnect the positive wire: 6 단계, 이미지 2/2
    • Disconnect the red positive wire's bullet connector.
  7. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Isolate the capacitor: 7 단계, 이미지 1/3 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Isolate the capacitor: 7 단계, 이미지 2/3 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Isolate the capacitor: 7 단계, 이미지 3/3
    • Grip the cable tie and slide it off the capacitors.
  8. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Discharge the capacitors: 8 단계, 이미지 1/1
    • If you have already discharged the capacitors, skip this step.
    • Follow this guide to discharge your capacitors.
  9. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Remove the capacitors: 9 단계, 이미지 1/2 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Remove the capacitors: 9 단계, 이미지 2/2
    • The capacitors are lightly adhered to the motor body.
    • Insert a flathead screwdriver underneath the capacitors, between the bottom cell and the adhesive.
    • Pry up to separate the bottom cell from the motor body.
  10. Titan Airless Sprayer IMPACT 410 Capacitor Replacement: 10 단계, 이미지 1/3 Titan Airless Sprayer IMPACT 410 Capacitor Replacement: 10 단계, 이미지 2/3 Titan Airless Sprayer IMPACT 410 Capacitor Replacement: 10 단계, 이미지 3/3
    • Insert a flathead screwdriver underneath the capacitors, between the top cell and the adhesive.
    • Pry up to separate the rest of the capacitor from the motor body.
    • Remove the capacitor.
    • During reassembly, if the adhesive is no longer sticky, replace it with double-sided foam adhesive.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Alex Diaz-Kokaisl
회원 가입일: 01/16/22
125,007 평판
안내서 582개 작성하였습니다
iFixit iFixit 회원
Staff
136 회원들
안내서 17,430개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 8
30일 전: 16
전체 시간: 295
