주요 콘텐츠로 건너뛰기
Toaster Oven Toasting Knob Replacement
필요한 것
  1. Toaster Oven Toasting Knob Replacement, Toasting knob: 1 단계, 이미지 1/3 Toaster Oven Toasting Knob Replacement, Toasting knob: 1 단계, 이미지 2/3 Toaster Oven Toasting Knob Replacement, Toasting knob: 1 단계, 이미지 3/3
    • Remove the two 4mm by 8mm screws from the back of the toaster oven.
  2. Toaster Oven Toasting Knob Replacement: 2 단계, 이미지 1/3 Toaster Oven Toasting Knob Replacement: 2 단계, 이미지 2/3 Toaster Oven Toasting Knob Replacement: 2 단계, 이미지 3/3
    • Remove the four 4mm by 8mm screws from the black supports from the base of the toaster oven.
    • Take the two supports off of the bottom.
  3. Toaster Oven Toasting Knob Replacement: 3 단계, 이미지 1/2 Toaster Oven Toasting Knob Replacement: 3 단계, 이미지 2/2
    • Remove the two 4mm by 4mm screws from the base in order to remove the tray.
  4. Toaster Oven Toasting Knob Replacement: 4 단계, 이미지 1/1
    • Slide the back panel off of the oven.
  5. Toaster Oven Toasting Knob Replacement: 5 단계, 이미지 1/1
    • Grip the sides of the metal cover and lift the cover up off the toaster oven top.
  6. Toaster Oven Toasting Knob Replacement: 6 단계, 이미지 1/3 Toaster Oven Toasting Knob Replacement: 6 단계, 이미지 2/3 Toaster Oven Toasting Knob Replacement: 6 단계, 이미지 3/3
    • The knob is missing in the first picture.
    • Push the knob into the hole.
    • The knob is now back in place in the last picture.
결론
Alissa Mell
회원 가입일: 09/26/17
101 평판
안내서 1개 작성함
Michigan Tech, Team S5-G25, Galliah Fall 2017 Michigan Tech, Team S5-G25, Galliah Fall 2017 회원
MTU-GALLIAH-F17S5G25
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 25
전체 시간: 1,859
