주요 콘텐츠로 건너뛰기
Toaster magnetic switch repair
필요한 것
  1. Toaster magnetic switch repair, Magnetic Switch: 1 단계, 이미지 2개 중 1개 Toaster magnetic switch repair, Magnetic Switch: 1 단계, 이미지 2개 중 2개
    • Remove five screws, but the screws at the top left and right are special screws. I was able to loosen them with needle-nosed pliers and some fumbling and replaced them with Phillips screws
    • The second picture shows the very repair-unfriendly screw. Thank you Phillips!
  2. Toaster magnetic switch repair, Detach side panel and cover: 2 단계, 이미지 2개 중 1개 Toaster magnetic switch repair, Detach side panel and cover: 2 단계, 이미지 2개 중 2개
    • The side wall can now be opened and removed together with the cover.
    • Do this carefully. I broke the cover
    • The control electronics are housed on the side wall and attached to the magnetic switch with a plug connection. The plug connection has to be loosened (in my case it almost came off by itself)
  3. Toaster magnetic switch repair, Remove magnetic switch: 3 단계, 이미지 2개 중 1개 Toaster magnetic switch repair, Remove magnetic switch: 3 단계, 이미지 2개 중 2개
    • The arrow points to the plug connection to the control electronics. When assembling, reattach accordingly
    • The magnetic switch is held in place by a clamp that is bolted to the bottom of the toaster (see second image).
    • I had toast crumbs between the magnets and the anchor, which prevented them from working properly. I removed/scraped off these crumbs.
    • Then reassemble in reverse order.
결론
Follow the steps in reverse order to reassemble your device.
다른 한 분이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
de en
100%
oldturkey03님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
작성자
2다른 기여자 명과 함께
Ingmar
회원 가입일: 05/01/20
136 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 17
지난 30일: 93
전체 시간: 3,078
