주요 콘텐츠로 건너뛰기
Toaster repair - home built tools (Mica Plate Punch)
  1. Toaster repair - home built tools (Mica Plate Punch), Toaster repair - home built tools (Mica Plate Punch): 1 단계, 이미지 3개 중 1개 Toaster repair - home built tools (Mica Plate Punch), Toaster repair - home built tools (Mica Plate Punch): 1 단계, 이미지 3개 중 2개 Toaster repair - home built tools (Mica Plate Punch), Toaster repair - home built tools (Mica Plate Punch): 1 단계, 이미지 3개 중 3개
    • Homemade tool, for the repair of bread toasters, in this case it is the perforator for the mica sheet, which will allow us to insert a screw that will join the two ends of the Nicrom thread, split, it is the 3rd tool that I have made when in fact it should have been the first.
    • This is the most basic and simple to make, it is the first one we will use in the repair, it is made with a chopstick, a small wood screw and a small nail, both reinforced with instant dry glue.
  2. Toaster repair - home built tools (Mica Plate Punch): 2 단계, 이미지 2개 중 1개 Toaster repair - home built tools (Mica Plate Punch): 2 단계, 이미지 2개 중 2개
    • Measure the nail with Caliper or "caliper foot" to use the most appropriate drill bit, in this case a thin nail of 2 mm.
  3. Toaster repair - home built tools (Mica Plate Punch): 3 단계, 이미지 2개 중 1개 Toaster repair - home built tools (Mica Plate Punch): 3 단계, 이미지 2개 중 2개
    • Inserting the nail, we must make the guide hole with the drill bit, this step is very important, otherwise the end of the stick will crack, before inserting the nail completely we will apply a drop of instant drying glue type cianolit so that it does not move with use.
  4. Toaster repair - home built tools (Mica Plate Punch): 4 단계, 이미지 3개 중 1개 Toaster repair - home built tools (Mica Plate Punch): 4 단계, 이미지 3개 중 2개 Toaster repair - home built tools (Mica Plate Punch): 4 단계, 이미지 3개 중 3개
    • Now we will do the same with the screw, we will use a drill bit slightly smaller than the screw we have once the hole is drilled, with a drill bit of larger diameter (the size of the screw head) we will make a slight "countersink" so that the head when tightening the screw is embedded.
  5. Toaster repair - home built tools (Mica Plate Punch): 5 단계, 이미지 3개 중 1개 Toaster repair - home built tools (Mica Plate Punch): 5 단계, 이미지 3개 중 2개 Toaster repair - home built tools (Mica Plate Punch): 5 단계, 이미지 3개 중 3개
    • We place the screw and tighten it, and when there are 3 or 4 mm left to finish tightening, we apply a drop of instant dry cyanolit and we finish tightening.
  6. Toaster repair - home built tools (Mica Plate Punch): 6 단계, 이미지 1개 중 1개
    • View of the inserted screw.
  7. Toaster repair - home built tools (Mica Plate Punch): 7 단계, 이미지 3개 중 1개 Toaster repair - home built tools (Mica Plate Punch): 7 단계, 이미지 3개 중 2개 Toaster repair - home built tools (Mica Plate Punch): 7 단계, 이미지 3개 중 3개
    • Images of the finished set.
  8. Toaster repair - home built tools (Mica Plate Punch): 8 단계, 이미지 2개 중 1개 Toaster repair - home built tools (Mica Plate Punch): 8 단계, 이미지 2개 중 2개
    • View of the finished homemade tool, useful to pierce the mica sheet at the point of breakage of the Nicrom thread in toasters and to be able to repair the thread. This tool is a complement of the following tools, being this the first one to be used to make the repair.
    • This is the 2nd tool that we will use in the repair of toasters with broken or broken nichrome wire, with this one we hold and place the screw: https://es.ifixit.com/Gu%C3%ADa/HERRAMIE...
    • This other tool is another option to the homemade tool 2nd is another model of homemade tool for fastening screws: https://es.ifixit.com/Gu%C3%ADa/HERRAMIE...
    • This tool will be used to illuminate the inside of the toaster: https://es.ifixit.com/Gu%C3%ADa/HERRAMIE...
    • Example of the use of the tools, in this case I used the first ones I made: https://es.ifixit.com/Gu%C3%ADa/TOSTADOR...
결론
This tool is a complement to the homemade tools already published; whose purpose is the repair of broken Nicrom thread in bread toasters:
다른 한 분이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
es en
100%
이 번역인들은 저희가 세상을 수리하는 데 도움을 주고 있어요! 기여하시겠습니까?
번역 시작하기 ›
작성자
1다른 기여자 명과 함께
Carlos López (España - Spain)
회원 가입일: 07/01/15
85,434 평판
안내서 285개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 15
전체 시간: 530
