주요 콘텐츠로 건너뛰기
Tofu65 Keyboard PCB Replacement
필요한 것
  1. Tofu65 Keyboard PCB Replacement, Keyboard PCB: 1 단계, 이미지 1개 중 1개
    • Unplug the power cord.
  2. Tofu65 Keyboard PCB Replacement: 2 단계, 이미지 1개 중 1개
    • Use a keycap puller to remove the keycaps from the keyboard.
    • Be sure to pull straight up when removing the keycaps to avoid damaging the key switches.
  3. Tofu65 Keyboard PCB Replacement: 3 단계, 이미지 1개 중 1개
    • Use the switch puller to pinch the switch on the two pins to release the switch from the PCB.
    • Pull straight up when removing the switch. It should not take much force to pull them out.
  4. Tofu65 Keyboard PCB Replacement: 4 단계, 이미지 2개 중 1개 Tofu65 Keyboard PCB Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the plastic cover that protects the PCB.
  5. Tofu65 Keyboard PCB Replacement: 5 단계, 이미지 2개 중 1개 Tofu65 Keyboard PCB Replacement: 5 단계, 이미지 2개 중 2개
    • Gently remove the foam layer protecting the PCB.
  6. Tofu65 Keyboard PCB Replacement: 6 단계, 이미지 3개 중 1개 Tofu65 Keyboard PCB Replacement: 6 단계, 이미지 3개 중 2개 Tofu65 Keyboard PCB Replacement: 6 단계, 이미지 3개 중 3개
    • Use a Phillips #000 screwdriver to remove the six 5 mm screws keeping the PCB in place.
  7. Tofu65 Keyboard PCB Replacement: 7 단계, 이미지 2개 중 1개 Tofu65 Keyboard PCB Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the old PCB from the bottom case.
  8. Tofu65 Keyboard PCB Replacement: 8 단계, 이미지 2개 중 1개 Tofu65 Keyboard PCB Replacement: 8 단계, 이미지 2개 중 2개
    • Ensure your keyboard switches are in good condition and the golden pins are not bent.
    • If the pins are bent, carefully bend them so they are straight or replace them with new switches.
  9. Tofu65 Keyboard PCB Replacement: 9 단계, 이미지 3개 중 1개 Tofu65 Keyboard PCB Replacement: 9 단계, 이미지 3개 중 2개 Tofu65 Keyboard PCB Replacement: 9 단계, 이미지 3개 중 3개
    • Replace your PCB.
    • Place the foam and plastic plate cover back.
    • Line up the key switch pins with the sockets on the PCB before installing them.
    • Install the keyboard switches and apply a small amount of force to ensure they make contact with the PCB.
  10. Tofu65 Keyboard PCB Replacement: 10 단계, 이미지 2개 중 1개 Tofu65 Keyboard PCB Replacement: 10 단계, 이미지 2개 중 2개
    • Replace each keycaps onto the appropriate switch.
    • Press down firmly on each to ensure they are making contact.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Daniel Payan
회원 가입일: 03/05/24
202 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 16
지난 30일: 69
전체 시간: 825
