주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Toilet Fill Valve Replacement
필요한 것
  1. Toilet Fill Valve Replacement, Tank Lid: 1 단계, 이미지 3개 중 1개 Toilet Fill Valve Replacement, Tank Lid: 1 단계, 이미지 3개 중 2개 Toilet Fill Valve Replacement, Tank Lid: 1 단계, 이미지 3개 중 3개
    • Lift the tank lid up and away from the toilet tank.
  2. Toilet Fill Valve Replacement, Shutting off the Water Supply to a Toilet: 2 단계, 이미지 2개 중 1개 Toilet Fill Valve Replacement, Shutting off the Water Supply to a Toilet: 2 단계, 이미지 2개 중 2개
    • Shut off the stop valve underneath the toilet by turning it clockwise until it becomes hand tight.
    • The appearance of this valve may differ from toilet to toilet, but most operate the same. Some valves require multiple turns to stop the water while others only require a quarter turn.
  3. Toilet Fill Valve Replacement, Refill Tube: 3 단계, 이미지 3개 중 1개 Toilet Fill Valve Replacement, Refill Tube: 3 단계, 이미지 3개 중 2개 Toilet Fill Valve Replacement, Refill Tube: 3 단계, 이미지 3개 중 3개
    • Disconnect the fill valve's rubber refill tube from the top of the overflow tube.
  4. Toilet Fill Valve Replacement, Draining a Toilet Tank: 4 단계, 이미지 2개 중 1개 Toilet Fill Valve Replacement, Draining a Toilet Tank: 4 단계, 이미지 2개 중 2개
    • Push down the flush lever.
    • Hold the lever down until water stops draining from the tank.
    • A small amount of water will remain in the bottom of the tank.
    • If the flush lever or pull chain have become disconnected, lift up the toilet flapper to drain the tank.
  5. Toilet Fill Valve Replacement, Sponge Drying a Toilet Tank: 5 단계, 이미지 3개 중 1개 Toilet Fill Valve Replacement, Sponge Drying a Toilet Tank: 5 단계, 이미지 3개 중 2개 Toilet Fill Valve Replacement, Sponge Drying a Toilet Tank: 5 단계, 이미지 3개 중 3개
    • Use a sponge to soak up and remove any remaining water from the toilet tank.
    • Periodically squeeze the excess water from the sponge.
  6. Toilet Fill Valve Replacement, Supply Tube: 6 단계, 이미지 3개 중 1개 Toilet Fill Valve Replacement, Supply Tube: 6 단계, 이미지 3개 중 2개 Toilet Fill Valve Replacement, Supply Tube: 6 단계, 이미지 3개 중 3개
    • Place a bucket under the supply tube to catch any dripping water.
    • Turn the coupling nut on the supply tube clockwise until it releases from the threaded shank on the bottom of the tank.
  7. Toilet Fill Valve Replacement, Fill Valve: 7 단계, 이미지 2개 중 1개 Toilet Fill Valve Replacement, Fill Valve: 7 단계, 이미지 2개 중 2개
    • Using an adjustable wrench, turn the locknut on the threaded shank counter-clockwise until it becomes loose.
  8. Toilet Fill Valve Replacement: 8 단계, 이미지 3개 중 1개 Toilet Fill Valve Replacement: 8 단계, 이미지 3개 중 2개 Toilet Fill Valve Replacement: 8 단계, 이미지 3개 중 3개
    • Turn the locknut counter-clockwise until it releases from the threaded shank.
  9. Toilet Fill Valve Replacement: 9 단계, 이미지 2개 중 1개 Toilet Fill Valve Replacement: 9 단계, 이미지 2개 중 2개
    • Lift the entire fill valve out of the tank.
    • When installing a new valve, be sure to adjust the float so that the water line stops one inch below the overflow tube.
결론
다른 18명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Kristen Gismondi
회원 가입일: 11/12/14
106,479 평판
안내서 270개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 25,721개를 작성함
5가이드 댓글
Great guide for removing the fill valve, but we're missing the steps for installing the new one. In the case of a Fluidmaster fill valve, you'll want to adjust the height to either match the one being replaced, or the more time-consuming (but not hard) method of marking the fill line of water on the tank, adjusting the fill valve to be just above that, then testing. Or ... is that another guide? For the present, I'd call this "removal." Perhaps we can create a new one for "installing a new fill valve." Ping me for assistance if needed.
David Spalding - 답글 공유
Hi David,
Thanks for checking out our guide! By default, all iFixit replacement guides conclude with "To reassemble your device, follow these instructions in reverse order." Our guide is intended to be a basic procedure that works for most fill valves. This particular fill valve is a Fluidmaster, and we do have an adjustment guide currently in the works. We'll also be updating our existing toilet guides, so make sure to check back soon.
We hope this clears everything up!
Kristen Gismondi - 답글 공유
Fluidmaster fill valve frequently fails to cut off, runs for awhile into overflow, THEN cuts off. Won’t cut off when manually toggled either. Water is hard, so could be lime deposit somewhere inside of valve. When water is turned off and tank drained for a couple of days, valve works for a few days. Any information appreciated.
Just Me - 답글 공유
ওই লেখাটা বাংলা কর
Murad Mia - 답글 공유
ইংলিশ লেখাটা সেটা বাংলা কর
Murad Mia - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 13
지난 7일: 203
지난 30일: 1,024
전체 시간: 16,227
