주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Toilet Flapper Replacement
  1. Toilet Flapper Replacement, Tank Lid: 1 단계, 이미지 3개 중 1개 Toilet Flapper Replacement, Tank Lid: 1 단계, 이미지 3개 중 2개 Toilet Flapper Replacement, Tank Lid: 1 단계, 이미지 3개 중 3개
    • Lift the tank lid up and away from the toilet tank.
  2. Toilet Flapper Replacement, Shutting off the Water Supply to a Toilet: 2 단계, 이미지 2개 중 1개 Toilet Flapper Replacement, Shutting off the Water Supply to a Toilet: 2 단계, 이미지 2개 중 2개
    • Shut off the stop valve underneath the toilet by turning it clockwise until it becomes hand tight.
    • The appearance of this valve may differ from toilet to toilet, but most operate the same. Some valves require multiple turns to stop the water while others only require a quarter turn.
  3. Toilet Flapper Replacement, Draining a Toilet Tank: 3 단계, 이미지 2개 중 1개 Toilet Flapper Replacement, Draining a Toilet Tank: 3 단계, 이미지 2개 중 2개
    • Push down the flush lever.
    • Hold the lever down until water stops draining from the tank.
    • A small amount of water will remain in the bottom of the tank.
    • If the flush lever or pull chain have become disconnected, lift up the toilet flapper to drain the tank.
  4. Toilet Flapper Replacement, Disassembling Toilet Pull Chain Spring Clasp: 4 단계, 이미지 3개 중 1개 Toilet Flapper Replacement, Disassembling Toilet Pull Chain Spring Clasp: 4 단계, 이미지 3개 중 2개 Toilet Flapper Replacement, Disassembling Toilet Pull Chain Spring Clasp: 4 단계, 이미지 3개 중 3개
    • Squeeze open the spring clasp that connects the pull chain to the tank lever.
    • Disconnect the spring clasp from the tank lever.
  5. Toilet Flapper Replacement, Flapper: 5 단계, 이미지 3개 중 1개 Toilet Flapper Replacement, Flapper: 5 단계, 이미지 3개 중 2개 Toilet Flapper Replacement, Flapper: 5 단계, 이미지 3개 중 3개
    • Disconnect the flapper from the posts on each side of the overflow tube.
    • Remove the flapper from the toilet tank.
결론
다른 8명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Kristen Gismondi
회원 가입일: 11/12/14
106,476 평판
안내서 270개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 25,721개를 작성함
2가이드 댓글
Thank you I needed that
My Mama - 답글 공유
How universal is the flapper size? Do I need to measure the existing one before buying a replacement?
John Clements - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 14
지난 7일: 72
지난 30일: 348
전체 시간: 18,239
