소개
Is your toilet seat always running, even when nobody has flushed it for hours? Or is your toilet incapable of flushing completely? When calcium deposits have built up on the valve seat, the toilet continues running and cannot be flushed. This guide will help you remove those calcium deposits.
필요한 것
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 3개
Thanks for Step #7. Always forget that one!
You may use a calcium remover for toilets. If you have patience and willingness, you can make a DIY toilet cleaner composed of vinegar, lemon, other acidic liquids, and baking soda. Thick calcium deposits in the toilet require muriatic acid and deep scrubbing with scour paper.
