주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Toilet Paper Holder Replacement
필요한 것
  1. Toilet Paper Holder Replacement, Toilet Paper Holder: 1 단계, 이미지 3개 중 1개 Toilet Paper Holder Replacement, Toilet Paper Holder: 1 단계, 이미지 3개 중 2개 Toilet Paper Holder Replacement, Toilet Paper Holder: 1 단계, 이미지 3개 중 3개
    • Unscrew the four screws of the original broken holder.
    • You may want to wear gloves.
    • If there is damage to the wall behind the old holder, check out the iFixit guide for repairing a hole in drywall.
  2. Toilet Paper Holder Replacement: 2 단계, 이미지 3개 중 1개 Toilet Paper Holder Replacement: 2 단계, 이미지 3개 중 2개 Toilet Paper Holder Replacement: 2 단계, 이미지 3개 중 3개
    • Measuring the area where you want your new holder to go, mark two lines 6.8" apart.
    • Measure an inch and a third (1 and 1/3") above the marks and mark these new spots where your screws will go.
    • While marking where you want to place the new holder, use a leveling tool to make sure that the toilet paper will be sitting flat.
  3. Toilet Paper Holder Replacement: 3 단계, 이미지 3개 중 1개 Toilet Paper Holder Replacement: 3 단계, 이미지 3개 중 2개 Toilet Paper Holder Replacement: 3 단계, 이미지 3개 중 3개
    • Place the new screw inside the new bracket and line up the mark with the base of the screw.
    • Make sure that the indentation for the toilet paper holder is facing in.
    • Repeat this for the top and bottom screws on both the left and right bracket bases (4 times total).
  4. Toilet Paper Holder Replacement: 4 단계, 이미지 3개 중 1개 Toilet Paper Holder Replacement: 4 단계, 이미지 3개 중 2개 Toilet Paper Holder Replacement: 4 단계, 이미지 3개 중 3개
    • Insert the spring loaded toilet roll bar and enjoy.
결론
Hopefully you have enjoyed exploring this repair guide and now understand how to repair and replace a broken toilet paper roll holder.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Elizabeth Opheim
회원 가입일: 01/19/16
121 평판
안내서 1개를 작성함
Oakland University, Team 6-1, Walwema Winter 2016 Oakland University, Team 6-1, Walwema Winter 2016 회원
OAK-WALWEMA-W16S6G1
10 회원들
안내서 13개를 작성함
1가이드 댓글
I don’t like the spring loaded holders. When we moved into our new house two years ago, One of the spring loaded holders was too far apart. Another was two close so roll would not rotate. The other two were ok. I replaced 3 of the 4 with the single arm holder. No need to fiddle with spring loaded holders. Slip on and slip off. Did the same at our previous house. I now have 3 spring loaded holders that I will donate or throw away.
Pete
Pete Chisteckoff - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 9
지난 30일: 56
전체 시간: 5,657
