주요 콘텐츠로 건너뛰기
Toilet Seat Replacement
필요한 것
  1. Toilet Seat Replacement, Toilet Seat: 1 단계, 이미지 1개 중 1개
    • Measure the size of your toilet bowl to know what size seat to purchase.
  2. Toilet Seat Replacement: 2 단계, 이미지 2개 중 1개 Toilet Seat Replacement: 2 단계, 이미지 2개 중 2개
    • Twist the tops of the hinges of the currently installed toilet seat and pull toilet seat off to expose the screws.
  3. Toilet Seat Replacement: 3 단계, 이미지 3개 중 1개 Toilet Seat Replacement: 3 단계, 이미지 3개 중 2개 Toilet Seat Replacement: 3 단계, 이미지 3개 중 3개
    • Unscrew the screws to detach the seat.
    • If the screw is not loosening but is spinning as if it were, then hold the back plastic nut so that it can unscrew from the nut.
    • Clean the newly exposed area. This opportunity will not present itself again anytime soon so take advantage of it.
  4. Toilet Seat Replacement: 4 단계, 이미지 2개 중 1개 Toilet Seat Replacement: 4 단계, 이미지 2개 중 2개
    • Insert new special 20mm screws that are provided with the purchase of the toilet seat in the holes and tighten them.
  5. Toilet Seat Replacement: 5 단계, 이미지 1개 중 1개
    • Then re install the toilet seat by fitting the heads of the screws in the holes on the hinges of the seat.
  6. Toilet Seat Replacement: 6 단계, 이미지 1개 중 1개
    • Close caps by twisting them in the opposite direction that you did to take off the seat.
결론
To re-install your previous seat, follow these instructions in reverse order.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Christopher Carter
회원 가입일: 02/24/15
231 평판
안내서 1개를 작성함
Cal Poly, Team 24-5, Green Winter 2015 Cal Poly, Team 24-5, Green Winter 2015 회원
CPSU-GREEN-W15S24G5
3 회원들
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 24
전체 시간: 2,187
