주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Toilet Tank Assembly Replacement
필요한 것
  1. Toilet Tank Assembly Replacement, Tank Lid: 1 단계, 이미지 3개 중 1개 Toilet Tank Assembly Replacement, Tank Lid: 1 단계, 이미지 3개 중 2개 Toilet Tank Assembly Replacement, Tank Lid: 1 단계, 이미지 3개 중 3개
    • Lift the tank lid up and away from the toilet tank.
  2. Toilet Tank Assembly Replacement, Shutting off the Water Supply to a Toilet: 2 단계, 이미지 2개 중 1개 Toilet Tank Assembly Replacement, Shutting off the Water Supply to a Toilet: 2 단계, 이미지 2개 중 2개
    • Shut off the stop valve underneath the toilet by turning it clockwise until it becomes hand tight.
    • The appearance of this valve may differ from toilet to toilet, but most operate the same. Some valves require multiple turns to stop the water while others only require a quarter turn.
  3. Toilet Tank Assembly Replacement, Draining a Toilet Tank: 3 단계, 이미지 2개 중 1개 Toilet Tank Assembly Replacement, Draining a Toilet Tank: 3 단계, 이미지 2개 중 2개
    • Push down the flush lever.
    • Hold the lever down until water stops draining from the tank.
    • A small amount of water will remain in the bottom of the tank.
    • If the flush lever or pull chain have become disconnected, lift up the toilet flapper to drain the tank.
  4. Toilet Tank Assembly Replacement, Sponge Drying a Toilet Tank: 4 단계, 이미지 3개 중 1개 Toilet Tank Assembly Replacement, Sponge Drying a Toilet Tank: 4 단계, 이미지 3개 중 2개 Toilet Tank Assembly Replacement, Sponge Drying a Toilet Tank: 4 단계, 이미지 3개 중 3개
    • Use a sponge to soak up and remove any remaining water from the toilet tank.
    • Periodically squeeze the excess water from the sponge.
  5. Toilet Tank Assembly Replacement, Supply Tube: 5 단계, 이미지 3개 중 1개 Toilet Tank Assembly Replacement, Supply Tube: 5 단계, 이미지 3개 중 2개 Toilet Tank Assembly Replacement, Supply Tube: 5 단계, 이미지 3개 중 3개
    • Place a bucket under the supply tube to catch any dripping water.
    • Turn the coupling nut on the supply tube clockwise until it releases from the threaded shank on the bottom of the tank.
  6. Toilet Tank Assembly Replacement, Tank Assembly: 6 단계, 이미지 3개 중 1개 Toilet Tank Assembly Replacement, Tank Assembly: 6 단계, 이미지 3개 중 2개 Toilet Tank Assembly Replacement, Tank Assembly: 6 단계, 이미지 3개 중 3개
    • Using a socket wrench to hold the nuts, unscrew the two tank bolts with a screwdriver.
    • When reattaching the tank, tighten the bolts with a screwdriver, rather than tightening the nuts. Alternately tighten each bolt in increments, until the tank fits snugly against the toilet.
    • Avoid over-tightening the tank bolts. Too much force can easily crack the toilet tank or toilet bowl.
  7. Toilet Tank Assembly Replacement: 7 단계, 이미지 2개 중 1개 Toilet Tank Assembly Replacement: 7 단계, 이미지 2개 중 2개
    • Lift the tank up from the lower half of the toilet.
    • Set the tank on a thick towel to avoid scraping it against the floor.
결론
다른 11명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Ron Davis
회원 가입일: 02/17/15
33,454 평판
안내서 13개를 작성함
3가이드 댓글
Step 5: Clockwise or counter-clockwise depends upon whether you are looking down at the coupling nut from above or up at it from below.
I suspect that, unless it has a left-handed thread, most people would turn it in the direction that works.
John Pretz - 답글 공유
Close your eyes. Attaching something, the turning motion is (usually) clockwise: Righty-tighty; lefty-loosey.
M J McAllister - 답글 공유
Thank you for the info.
DonnaRHellman - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 52
지난 30일: 282
전체 시간: 18,238
