소개
Use this guide to replace the entire tank assembly on a gravity flush toilet. Removing the entire tank assembly is a helpful step when moving a toilet or replacing the toilet bowl.
부품
지정된 부품이 없습니다.
Shut off the stop valve underneath the toilet by turning it clockwise until it becomes hand tight.
Push down the flush lever.
Hold the lever down until water stops draining from the tank.
Use a sponge to soak up and remove any remaining water from the toilet tank.
Periodically squeeze the excess water from the sponge.
Place a bucket under the supply tube to catch any dripping water.
Turn the coupling nut on the supply tube clockwise until it releases from the threaded shank on the bottom of the tank.
Using a socket wrench to hold the nuts, unscrew the two tank bolts with a screwdriver.
다른 9명이 해당 안내서를 완성하였습니다.
댓글 3개
Step 5: Clockwise or counter-clockwise depends upon whether you are looking down at the coupling nut from above or up at it from below.
I suspect that, unless it has a left-handed thread, most people would turn it in the direction that works.
John Pretz - 답글
Close your eyes. Attaching something, the turning motion is (usually) clockwise: Righty-tighty; lefty-loosey.
Thank you for the info.
