주요 콘텐츠로 건너뛰기
Toloco EM26 Large Motherboard Replacement
필요한 것
  1. Toloco EM26 Large Motherboard Replacement, Large Motherboard: 1 단계, 이미지 2개 중 1개 Toloco EM26 Large Motherboard Replacement, Large Motherboard: 1 단계, 이미지 2개 중 2개
    • Remove rubber pieces at the bottom of the massage gun’s barrel with the spudger by inserting it between the rubber and the plastic, and use the tip of the spudger to pry the rubber out.
  2. Toloco EM26 Large Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the two 13.48 mm screws on the bottom of the massage gun with a Phillips #00 screwdriver.
  3. Toloco EM26 Large Motherboard Replacement: 3 단계, 이미지 2개 중 1개 Toloco EM26 Large Motherboard Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the 8.11 mm small black screw on the edge of circular plate with a Phillips #00 Screwdriver.
  4. Toloco EM26 Large Motherboard Replacement: 4 단계, 이미지 1개 중 1개
    • Take off the cap of the massage gun by simply lifting it off the device.
    • Be careful to secure the cap as the back part of the gun may fall.
  5. Toloco EM26 Large Motherboard Replacement: 5 단계, 이미지 1개 중 1개
    • Pull out back touch plate to access the large motherboard.
  6. Toloco EM26 Large Motherboard Replacement: 6 단계, 이미지 2개 중 1개 Toloco EM26 Large Motherboard Replacement: 6 단계, 이미지 2개 중 2개
    • Unplug the three cables on large motherboard.
    • The largest cable has a tiny lever which has to be pressed down first to remove.
  7. Toloco EM26 Large Motherboard Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the three 7.66 mm silver screws on the large motherboard with the Phillips #00 screwdriver.
  8. Toloco EM26 Large Motherboard Replacement: 8 단계, 이미지 1개 중 1개
    • Remove large motherboard for replacement.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Zachary Olsen
회원 가입일: 09/08/23
536 평판
안내서 3개를 작성함
1가이드 댓글
Greetings!
Any idea where to get replacement parts for the Toloco EM26 massage gun?
Thanks,
Kev
Kevixfix - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 129
전체 시간: 1,113
