소개
The motherboard contains all of the device's ports while the speaker, battery, and microphone are separate from the motherboard. Confirm the device is powered off before starting the disassembly.
필요한 것
Unscrew the two 3mm screws at the base of the device using the Torx T5 screwdriver.
거의 끝나갑니다!
결론
다른 4명이 해당 안내서를 완성하였습니다.
