주요 콘텐츠로 건너뛰기
TomTom GO Live 1535M Reset Button Activation
필요한 것
  1. TomTom GO Live 1535M Reset Button Activation, Reset Button: 1 단계, 이미지 1/1
    • The reset button is located at the top of the device, close to the charging port. It is a small hole that is .78 mm wide.
    • Insert one end of the paper clip into the small power button hole and press down gently until you hear a "click" sound.
    • Hold paper clip in power button hole for 15 seconds.
    • The device should power on by itself with its factory default settings in place once done. If you do not see the screen power on, go back to step 1 and try repowering again.
결론
Mathias Sagide
회원 가입일: 01/20/15
618 평판
안내서 5개 작성하였습니다
USF Tampa, Team 19-4, Blackwell Spring 2014 USF Tampa, Team 19-4, Blackwell Spring 2014 회원
USFT-BLACKWELL-S14S19G4
1 회원
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 12
전체 시간: 3,164
