소개
If your TomTom Go Live does not seem to be charging or hold said charge, then the battery needs to be replaced. This guide will show how to take this device apart and replace the battery without damaging the screen or cables.
필요한 것
Slip a small opening tool underneath the screen, gently sliding it around the outside edge.
Simply lift the battery up and out of the base.
Remove the cable.
Replace the battery.
다른 4명이 해당 안내서를 완성하였습니다.
