주요 콘텐츠로 건너뛰기
TomTom GO Live 1535M Speaker Replacement
필요한 것
  1. TomTom GO Live 1535M Speaker Replacement, Motherboard: 1 단계, 이미지 1/1
    • Slip a small opening tool underneath the screen, gently sliding it around the outside edge.
    • It may be easier to start at the corners.
  2. TomTom GO Live 1535M Speaker Replacement: 2 단계, 이미지 1/2 TomTom GO Live 1535M Speaker Replacement: 2 단계, 이미지 2/2
    • Carefully remove the reset button cable (located on the left) and the ribbon cable.
    • Remove the screen and set it aside.
  3. TomTom GO Live 1535M Speaker Replacement: 3 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Remove the logic board cables.
    • We highly advice that a pair of tweezers are used for this step to ensure no part is damaged.
  4. TomTom GO Live 1535M Speaker Replacement: 4 단계, 이미지 1/1
    • Remove the 3.6mm screws with a Phillips Screwdriver.
    • After removing the screws simply lift the logic board from the base.
  5. TomTom GO Live 1535M Speaker Replacement, Speaker: 5 단계, 이미지 1/1
    • Simply lift the speaker up and out of the base to replace it.
결론
Mathias Sagide
회원 가입일: 01/20/15
618 평판
안내서 5개 작성하였습니다
USF Tampa, Team 19-4, Blackwell Spring 2014 USF Tampa, Team 19-4, Blackwell Spring 2014 회원
USFT-BLACKWELL-S14S19G4
1 회원
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 9
전체 시간: 263
