주요 콘텐츠로 건너뛰기
TomTom Go 60 S Speaker Replacement
필요한 것
  1. TomTom Go 60 S Speaker Replacement, Speaker: 1 단계, 이미지 1/1
    • Use the iFixit opening tool to pry open the TomTom Go 60 S. Start from a corner and drag the tool around the device.
  2. TomTom Go 60 S Speaker Replacement: 2 단계, 이미지 1/1
    • Disconnect the screen from the motherboard by removing the yellow ribbon connector from the socket.
  3. TomTom Go 60 S Speaker Replacement: 3 단계, 이미지 1/1
    • Remove all six screws from the motherboard with a Philips #000 screwdriver.
  4. TomTom Go 60 S Speaker Replacement: 4 단계, 이미지 1/2 TomTom Go 60 S Speaker Replacement: 4 단계, 이미지 2/2
    • Disconnect the battery and speaker ribbon cables from the motherboard.
  5. TomTom Go 60 S Speaker Replacement: 5 단계, 이미지 1/2 TomTom Go 60 S Speaker Replacement: 5 단계, 이미지 2/2
    • Use a spudger to remove the speaker from back case.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Tomy Peralta
회원 가입일: 10/04/16
133 평판
안내서 3개 작성하였습니다
USF Tampa, Team 1-6, Nance Fall 2016 USF Tampa, Team 1-6, Nance Fall 2016 회원
USFT-NANCE-F16S1G6
4 회원들
안내서 5개 작성하였습니다
댓글 2개
This is not a button cell battery, it is a speaker
Jurgen Bullaert - 답글
Hi @jurgenbullaert, Good catch. We've corrected the errors in the guide. Thanks for your help!
Sarah Westberg -
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 10
전체 시간: 1,420
