주요 콘텐츠로 건너뛰기
TomTom Go 60 S Lithium Ion Battery Replacement
필요한 것
  1. TomTom Go 60 S Lithium Ion Battery Replacement, Lithium Ion Battery: 1 단계, 이미지 1/1
    • Use the iFixit opening tool to pry open the TomTom Go 60 S. Start from a corner and drag the tool around the device.
  2. TomTom Go 60 S Lithium Ion Battery Replacement: 2 단계, 이미지 1/1
    • Your device should now look like this. Make sure to disconnect the screen from the motherboard by removing the flap connecting both, so you have ample room to work on the device.
  3. TomTom Go 60 S Lithium Ion Battery Replacement: 3 단계, 이미지 1/1
    • Remove all the screws that are marked in the image with a Philips #000 screwdriver and over a magnetic work mat.
  4. TomTom Go 60 S Lithium Ion Battery Replacement: 4 단계, 이미지 1/1
    • Disconnect battery wires from motherboard, so that you can remove the Lithium-Ion battery.
  5. TomTom Go 60 S Lithium Ion Battery Replacement: 5 단계, 이미지 1/1
    • Detach from holster and replace Lithium-Ion battery.
결론
Tomy Peralta
회원 가입일: 10/04/16
133 평판
안내서 3개 작성하였습니다
USF Tampa, Team 1-6, Nance Fall 2016 USF Tampa, Team 1-6, Nance Fall 2016 회원
USFT-NANCE-F16S1G6
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 7
7일 전: 13
30일 전: 35
전체 시간: 2,524
