소개
If you need to replace the speaker of your TomTom Go 60 S, use this guide. After removing the covering for the device, the button cell battery will be located underneath the motherboard.
Before you begin the repair, turn off the device and disconnect the battery from the motherboard.
필요한 것
Use the iFixit opening tool to pry open the TomTom Go 60 S. Start from a corner and drag the tool around the device.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 2개
This is not a button cell battery, it is a speaker
Hi @jurgenbullaert, Good catch. We've corrected the errors in the guide. Thanks for your help!
