주요 콘텐츠로 건너뛰기
TomTom ONE Motherboard Replacement
필요한 것
  1. TomTom ONE Motherboard Replacement, Motherboard: 1 단계, 이미지 1/1
    • Use a T-9 Torx screwdriver to unscrew the four screws on the back cover.
  2. TomTom ONE Motherboard Replacement: 2 단계, 이미지 1/2 TomTom ONE Motherboard Replacement: 2 단계, 이미지 2/2
    • Using the spudger, gently pry apart the back case from the front case. It is easier to start on a side and work your way around the device.
  3. TomTom ONE Motherboard Replacement: 3 단계, 이미지 1/1
    • Carefully pull the back cover apart from the front cover. Be careful not to pull too hard because there are two sets of wires connecting the device.
  4. TomTom ONE Motherboard Replacement: 4 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Once the two covers are separated, use tweezers, or even your fingers, to gently disconnect the two sets of wires that are connected to the motherboard from the back cover.
  5. TomTom ONE Motherboard Replacement: 5 단계, 이미지 1/1
    • Next, you must remove the motherboard from the front screen.
    • Use a Torx T-7 screwdriver to unscrew the two screws.
  6. TomTom ONE Motherboard Replacement: 6 단계, 이미지 1/2 TomTom ONE Motherboard Replacement: 6 단계, 이미지 2/2
    • Before you can seperate the motherboard from the front cover, you must disconnect the wire connecting the two.
    • To do so, you must use the back end of the spudger to push out the two white tabs connected to the wire, that holds the motherboard and front cover together.
  7. TomTom ONE Motherboard Replacement: 7 단계, 이미지 1/1
    • The motherboard is now disconnected from the front assembly
결론
다른 4명이 해당 안내서를 완성하였습니다.
Becca
회원 가입일: 04/16/10
211 평판
안내서 2개 작성하였습니다
Cal Poly, Team 7-7, Maness Spring 2010 Cal Poly, Team 7-7, Maness Spring 2010 회원
CPSU-MANESS-S10S7G7
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 10,066
