주요 콘텐츠로 건너뛰기
TomTom ONE Screen Replacement
필요한 것
  1. TomTom ONE Screen Replacement, Screen: 1 단계, 이미지 1/1
    • Use a T-9 Torx screwdriver to unscrew the four screws on the back cover.
  2. TomTom ONE Screen Replacement: 2 단계, 이미지 1/2 TomTom ONE Screen Replacement: 2 단계, 이미지 2/2
    • Using the spudger, gently pry apart the back case from the front case. It is easier to start on a side and work your way around the device.
  3. TomTom ONE Screen Replacement: 3 단계, 이미지 1/1
    • Carefully pull the back cover apart from the front cover. Be careful not to pull too hard because there are two sets of wires connecting the device.
  4. TomTom ONE Screen Replacement: 4 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Once the two covers are separated, use the tweezers, or even your fingers, to gently disconnect the two sets of wires that are connected to the motherboard from the back cover. You may have to wiggle the wires a little bit to get them to disconnect.
  5. TomTom ONE Screen Replacement: 5 단계, 이미지 1/1
    • Next, you must remove the motherboard from the front screen.
    • Use a Torx T-7 screwdriver to unscrew the two screws.
  6. TomTom ONE Screen Replacement: 6 단계, 이미지 1/2 TomTom ONE Screen Replacement: 6 단계, 이미지 2/2
    • Before you can seperate the motherboard from the front cover, you must disconnect the wire connecting the two.
    • To do so, you must use the back end of the spudger to push out the two white tabs connected to the wire, that holds the motherboard and front cover together.
  7. TomTom ONE Screen Replacement: 7 단계, 이미지 1/1
    • Once separated, use the spudger to pry around the edges of the outer casing.
  8. TomTom ONE Screen Replacement: 8 단계, 이미지 1/2 TomTom ONE Screen Replacement: 8 단계, 이미지 2/2
    • Apply pressure with thumbs to remove screen from inner casing.
    • The screen and front cover are now disconnected.
결승점
다른 2명이 해당 안내서를 완성하였습니다.
Alex Cauvy
회원 가입일: 04/18/10
41 평판
안내서 1개 작성함
Cal Poly, Team 7-7, Maness Spring 2010 Cal Poly, Team 7-7, Maness Spring 2010 회원
CPSU-MANESS-S10S7G7
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 6
전체 시간: 9,819
