주요 콘텐츠로 건너뛰기
TomTom One XL Battery Replacement
필요한 것
  1. TomTom One XL Battery Replacement, Back Panel: 1 단계, 이미지 1/2 TomTom One XL Battery Replacement, Back Panel: 1 단계, 이미지 2/2
    • Remove the 4 .4mm screws on the back of the device.
  2. TomTom One XL Battery Replacement: 2 단계, 이미지 1/1
    • Using the palate knife tool, pry the back from the LCD screen. Apply a moderate pressure to separate them.
    • You can rotate TOMTOM XL to make prying back off easier.
    • Be careful not to injure the two wires connecting the pieces.
  3. TomTom One XL Battery Replacement: 3 단계, 이미지 1/1
    • After prying both halves apart, they will be connected by two wires.
    • Carefully set the two halves next to each other making sure not to stress or damage the wires.
  4. TomTom One XL Battery Replacement: 4 단계, 이미지 1/2 TomTom One XL Battery Replacement: 4 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Using the tweezers separate the wires connecting the battery and speaker to the mother board.
    • Be gentle while pulling the wires out, the plugs are easily injured.
  5. TomTom One XL Battery Replacement, Battery: 5 단계, 이미지 1/1
    • Using metal palate knife pry the battery from the back panel.
  6. TomTom One XL Battery Replacement: 6 단계, 이미지 1/3 TomTom One XL Battery Replacement: 6 단계, 이미지 2/3 TomTom One XL Battery Replacement: 6 단계, 이미지 3/3
    • Place the backside of the battery on the sticky side of the double sided tape.
    • Using the tech knife, trim the extra tape to the size of the battery.
    • The tech knife is sharp, be careful when cutting the tape.
  7. TomTom One XL Battery Replacement: 7 단계, 이미지 1/3 TomTom One XL Battery Replacement: 7 단계, 이미지 2/3 TomTom One XL Battery Replacement: 7 단계, 이미지 3/3
    • Remove the back of the double sided tap.
    • Place the new battery back inside the back panel of TOMTOM XL.
    • Make sure the wire from the battery is going in the correct direction.
  8. TomTom One XL Battery Replacement: 8 단계, 이미지 1/3 TomTom One XL Battery Replacement: 8 단계, 이미지 2/3 TomTom One XL Battery Replacement: 8 단계, 이미지 3/3
    • Reconnect the battery ribbon cable to its port.
결론
DeVhan
회원 가입일: 03/11/15
401 평판
안내서 4개 작성하였습니다
Colorado Springs, Team 9-6, Panko Spring 2015 Colorado Springs, Team 9-6, Panko Spring 2015 회원
UCCS-PANKO-S15S9G6
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 16
전체 시간: 1,463
