주요 콘텐츠로 건너뛰기
TomTom One XL Charging Port Replacement
필요한 것
  1. TomTom One XL Charging Port Replacement, Back Panel: 1 단계, 이미지 1/2 TomTom One XL Charging Port Replacement, Back Panel: 1 단계, 이미지 2/2
    • Remove the 4 .4mm screws on the back of the device.
  2. TomTom One XL Charging Port Replacement: 2 단계, 이미지 1/1
    • Using the palate knife tool, pry the back from the LCD screen. Apply a moderate pressure to separate them.
    • You can rotate TOMTOM XL to make prying back off easier.
    • Be careful not to injure the two wires connecting the pieces.
  3. TomTom One XL Charging Port Replacement: 3 단계, 이미지 1/1
    • After prying both halves apart, they will be connected by two wires.
    • Carefully set the two halves next to each other making sure not to stress or damage the wires.
  4. TomTom One XL Charging Port Replacement: 4 단계, 이미지 1/2 TomTom One XL Charging Port Replacement: 4 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Using the tweezers separate the wires connecting the battery and speaker to the mother board.
    • Be gentle while pulling the wires out, the plugs are easily injured.
  5. TomTom One XL Charging Port Replacement, Charging Port: 5 단계, 이미지 1/2 TomTom One XL Charging Port Replacement, Charging Port: 5 단계, 이미지 2/2
    • If this is your first time solder then refer to IFixIt's safety guide.
    • Locate where the charger port goes on the circuit board.
    • Locate the four connecter on circuit board and charger port which need to be soldered.
    • Don't forget, the soldering iron is hot.
  6. TomTom One XL Charging Port Replacement: 6 단계, 이미지 1/3 TomTom One XL Charging Port Replacement: 6 단계, 이미지 2/3 TomTom One XL Charging Port Replacement: 6 단계, 이미지 3/3
    • Using your plastic opening tool press down firmly on the top of the charger port.
    • While the soldering iron is hot press it again the four corners of the charger port.
    • Don't touch the charger port with your hands, it may have heated up during soldering.
  7. TomTom One XL Charging Port Replacement: 7 단계, 이미지 1/3 TomTom One XL Charging Port Replacement: 7 단계, 이미지 2/3 TomTom One XL Charging Port Replacement: 7 단계, 이미지 3/3
    • Let the circuit board and charger port cool down for a few minutes.
    • Lift circuit board up, after making sure its cool, to see if four corners are all connected.
    • Plug in the charger to make sure it works, if not repeat steps and make sure the port is making a clean connection.
결론
DeVhan
회원 가입일: 03/11/15
401 평판
안내서 4개 작성하였습니다
Colorado Springs, Team 9-6, Panko Spring 2015 Colorado Springs, Team 9-6, Panko Spring 2015 회원
UCCS-PANKO-S15S9G6
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 9
전체 시간: 2,411
