주요 콘텐츠로 건너뛰기
TomTom One XL Power Button Replacement
필요한 것
  1. TomTom One XL Power Button Replacement, Back Panel: 1 단계, 이미지 1/2 TomTom One XL Power Button Replacement, Back Panel: 1 단계, 이미지 2/2
    • Remove the 4 .4mm screws on the back of the device.
  2. TomTom One XL Power Button Replacement: 2 단계, 이미지 1/1
    • Using the palate knife tool, pry the back from the LCD screen. Apply a moderate pressure to separate them.
    • You can rotate TOMTOM XL to make prying back off easier.
    • Be careful not to injure the two wires connecting the pieces.
  3. TomTom One XL Power Button Replacement: 3 단계, 이미지 1/1
    • After prying both halves apart, they will be connected by two wires.
    • Carefully set the two halves next to each other making sure not to stress or damage the wires.
  4. TomTom One XL Power Button Replacement: 4 단계, 이미지 1/2 TomTom One XL Power Button Replacement: 4 단계, 이미지 2/2
    • Using the tweezers separate the wires connecting the battery and speaker to the mother board.
    • Be gentle while pulling the wires out, the plugs are easily injured.
  5. TomTom One XL Power Button Replacement, Power Button: 5 단계, 이미지 1/1
    • Using a Torx 6 screwdriver, remove the 4 .5mm screws connecting the motherboard to the screen assembly.
    • The motherboard is connected to the screen assembly via a ribbon wire. After removing the screws, be careful not to damage the wire or the port.
  6. TomTom One XL Power Button Replacement: 6 단계, 이미지 1/2 TomTom One XL Power Button Replacement: 6 단계, 이미지 2/2
    • Detach the ribbon wire from it's port on the back of the motherboard.
  7. TomTom One XL Power Button Replacement: 7 단계, 이미지 1/3 TomTom One XL Power Button Replacement: 7 단계, 이미지 2/3 TomTom One XL Power Button Replacement: 7 단계, 이미지 3/3
    • Now the power button is exposed and any obstructions can be easily removed.
    • If you want to replace the button it can easily be popped out using your hands.
결론
Jesse
회원 가입일: 03/11/15
101 평판
안내서 1개 작성함
Colorado Springs, Team 9-6, Panko Spring 2015 Colorado Springs, Team 9-6, Panko Spring 2015 회원
UCCS-PANKO-S15S9G6
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 10
전체 시간: 2,186
