이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
First, lift the bottom part of the band to start removing the wristband from the button area of the watch.
Continue to lift up on the band until the screen of the watch becomes loose from the band.
Continue to pull up on the wristband until it is completely off the watch.
Flip over the watch and remove the four 3.0 mm Torx head screws with a T4 Torx head screwdriver.
Remove the two 3.0 mm Torx screws from the front. Use a T4 Torx screwdriver to remove the screws.
The two 3.0 mm Torx screws are painted blue at the end. These screws have screw holders around them that will also need to be removed.
Unscrew the screws from the front of the watch casing and the screw holders fall out from the back of the watch casing.
Gently wiggle the black box vibrator component away from the back panel with your fingers or a Spudger tool.
이 단계에 사용된 도구:Tweezers$4.99-
Now lift the smaller square of copper off the front panel. Use the precision tweezers and slide it under the smaller square of copper lining then gently lift it up.
Use your fingers to gently grab and lift the small square piece to remove the GPS and button component competely from the casing.
Disconnect the ZIF Connector from the larger green motherboard.
The ZIF Connector is the flat, orange cable connecting the small green motherboard to the larger motherboard. It is meant to come apart at the port located on the larger motherboard. You will feel like you have broken it when it is disconnected. That is okay!
Get the GPS/Button Component by itself and use the Spudger tool to lift the silver cover off the GPS Component. This will expose the GPS Component.
Once the GPS Component cover is off and the GPS Component is exposed, you are ready to replace it.
댓글 2개
Where do i buy the GPS component for replacement?
Hi,
Thanx so much for this guide. Now I’m looking for a new GPS component.Do you know where I can buy that?
Regards, Rein Kooijman (the Netherlands)
