소개
The motherboard is a large and central part to the GPS, with most components either connected or interfaced with it. Since this must be removed or dislodged in order to reach other interior components of the device, this guide will show how to remove it properly.
필요한 것
Wedge a spudger between the white plastic latch and the black connection port, disconnecting the gold ribbon cable.
Slide the gold ribbon cable out of the port.
다른 한 분이 해당 안내서를 완성하였습니다.
