주요 콘텐츠로 건너뛰기
TomTom VIA 1605TM Motherboard Replacement
필요한 것
  1. TomTom VIA 1605TM Motherboard  Replacement, Front Screen: 1 단계, 이미지 1/3 TomTom VIA 1605TM Motherboard  Replacement, Front Screen: 1 단계, 이미지 2/3 TomTom VIA 1605TM Motherboard  Replacement, Front Screen: 1 단계, 이미지 3/3
    • Locate the round suction cup on the back of the device.
    • Twist the suction cup clockwise or counterclockwise while pulling back away from the device closer to your body until removed.
    • When reassembling twist the suction cup but, push in as oppose to pulling out.
  2. TomTom VIA 1605TM Motherboard  Replacement: 2 단계, 이미지 1/1
    • Location of screw is where the suction cup was.
    • Insert 8mm Hex #T6 screw driver into screw.
    • Unscrew in counter clockwise direction.
    • When reassembling screw in the clockwise direction.
  3. TomTom VIA 1605TM Motherboard  Replacement: 3 단계, 이미지 1/2 TomTom VIA 1605TM Motherboard  Replacement: 3 단계, 이미지 2/2
    • Pry along the edges with the plastic opening tool to separate the back and front panel.
    • Try not to tear the screen open as you may break the part. Go about this gently but with enough force to remove the screen.
  4. TomTom VIA 1605TM Motherboard  Replacement: 4 단계, 이미지 1/3 TomTom VIA 1605TM Motherboard  Replacement: 4 단계, 이미지 2/3 TomTom VIA 1605TM Motherboard  Replacement: 4 단계, 이미지 3/3
    • Place the new front panel (with new screen) on to the back panel. Press firmly along the edges to attach.
    • Only do this step of placing the front panel on if you are completed. If there are still components needed replacing postpone this step until the end.
  5. TomTom VIA 1605TM Motherboard  Replacement, Motherboard: 5 단계, 이미지 1/3 TomTom VIA 1605TM Motherboard  Replacement, Motherboard: 5 단계, 이미지 2/3 TomTom VIA 1605TM Motherboard  Replacement, Motherboard: 5 단계, 이미지 3/3
    • Keep the TOMTOM oriented so the curve is on the bottom. Locate the four 1mm Philips #J1 head screws attached to the motherboard.
    • Unscrew each of these in a counter clockwise direction.
    • When reassembling screw back in a clockwise direction.
    • The second picture is to represent where the four screws are located. The LCD screen does not disconnect from the motherboard until the next step.
  6. TomTom VIA 1605TM Motherboard  Replacement: 6 단계, 이미지 1/3 TomTom VIA 1605TM Motherboard  Replacement: 6 단계, 이미지 2/3 TomTom VIA 1605TM Motherboard  Replacement: 6 단계, 이미지 3/3
    • Remove the Blue Ribbon Cable by pushing each side of the plastic holder with the nylon spudger.
    • This will remove the LCD screen from the motherboard.
  7. TomTom VIA 1605TM Motherboard  Replacement: 7 단계, 이미지 1/1
    • Unplug the wire connecting to the speaker by pinching the sides connected to the back screen.
    • Pull back away (in the opposite direction) from the connector.
    • When reassembling push back into connector. Do not need to pinch anything. The "click" sound ensures solid connection.
  8. TomTom VIA 1605TM Motherboard  Replacement: 8 단계, 이미지 1/2 TomTom VIA 1605TM Motherboard  Replacement: 8 단계, 이미지 2/2
    • Unplug the battery, the same way we unplugged the speaker by pinching the sides of the connection.
    • Pull away from the connector
  9. TomTom VIA 1605TM Motherboard  Replacement: 9 단계, 이미지 1/1
    • Properly dispose of the old motherboard. Replace with the new motherboard.
    • Skip this step(i.e. do not dispose of motherboard) if this part of prerequisite guide for the back cover replacement.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Tyler Wade
회원 가입일: 10/15/15
362 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 4-4, Catania Fall 2015 UMass Dartmouth, Team 4-4, Catania Fall 2015 회원
UMASSD-CATANIA-F15S4G4
4 회원들
안내서 5개 작성하였습니다
댓글 한 개
Trying to figure out y my gps is changing screen manual even i don't touch screen
Joseph Fixler - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 5
30일 전: 11
전체 시간: 746
