주요 콘텐츠로 건너뛰기
TomTom XL Battery Replacement
필요한 것
  1. TomTom XL Battery Replacement, Screen and Motherboard: 1 단계, 이미지 1/1
    • Slip a small plastic opening tool underneath the screen bezel, gently sliding it around the inside edge.
    • Starting at the corners, carefully pry up the screen bezel.
  2. TomTom XL Battery Replacement: 2 단계, 이미지 1/1
    • Remove the four Phillips #00 screws around the edge of the screen.
  3. TomTom XL Battery Replacement: 3 단계, 이미지 1/3 TomTom XL Battery Replacement: 3 단계, 이미지 2/3 TomTom XL Battery Replacement: 3 단계, 이미지 3/3
    • Slide a small plastic opening tool under the top portion of the metal frame and gently lift it up.
    • Slide the plastic opening tool around the inner edge of the metal frame until it feels loose.
    • It may take some time to release the frame from the housing. Some force may be necessary—but be careful not to bend the frame's fragile interior bracket.
    • Remove the frame from the housing.
  4. TomTom XL Battery Replacement: 4 단계, 이미지 1/2 TomTom XL Battery Replacement: 4 단계, 이미지 2/2
    • Lifting from the upper edge of the screen, tilt the screen away from the device.
    • Tilt the screen slowly. Flipping the screen up too quickly may damage the display cable.
  5. TomTom XL Battery Replacement: 5 단계, 이미지 1/2 TomTom XL Battery Replacement: 5 단계, 이미지 2/2
    • Remove the three Phillips #00 screws connecting the motherboard to the plastic housing:
    • Two Phillips #00 screws are located at the bottom of the first picture.
    • The third screw is hidden under the orange ribbon cable, near the screen.
    • You may have to carefully lift the screen in order to reach this screw.
  6. TomTom XL Battery Replacement: 6 단계, 이미지 1/2 TomTom XL Battery Replacement: 6 단계, 이미지 2/2
    • Flip the screen and motherboard over.
    • Gripping the plastic casing, disconnect the battery cable connector from the motherboard.
    • Disconnect the speaker cable connector from the motherboard.
    • Remove the motherboard and screen from the housing.
  7. TomTom XL Battery Replacement, Battery: 7 단계, 이미지 1/1
    • Slip a small plastic opening tool under the battery and slowly pry the battery up.
    • The battery is held on with strong adhesive, so it may require some force. Work slowly and carefully to avoid damaging the housing
    • Remove the battery from the housing.
결론
다른 13명이 해당 안내서를 완성하였습니다.
Sean Higginson
회원 가입일: 04/21/10
209 평판
안내서 2개 작성하였습니다
Cal Poly, Team 33-84, Johann Spring 2010 Cal Poly, Team 33-84, Johann Spring 2010 회원
CPSU-JOHANN-S10S33G84
4 회원들
안내서 5개 작성하였습니다
댓글 12개
Note: There are several variants of this. Some of them have 2 screws on the bottom under the stickers. You'll need to remove those first.
nathan - 답글
Awesome and very detailed guide. Thanks for this.
Phil Harris - 답글
Great demo, for replacement tomtom batteries take a look at : TomTom batteries
based in the UK they are reliable and give a truly longer charge
Kermit45 - 답글
This was a great help. Followed the instructions and it was that easy. Thanks
mark - 답글
nathanrenniewaldock is right... I cracked my screen before finding the hidden screws on the bottom. what a silly company to use the same name for different models!
Laz - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 6
30일 전: 31
전체 시간: 51,440
