주요 콘텐츠로 건너뛰기
TomTom XXL 540 Screen Replacement
필요한 것
  1. TomTom XXL 540  Screen Replacement, Screen: 1 단계, 이미지 1/1
    • Peel back the sticker, using the tweezers on the bottom of the device to reveal the two screws.
  2. TomTom XXL 540  Screen Replacement: 2 단계, 이미지 1/1
    • Unscrew the two T5 screws using the T5 Torx Screwdriver.
  3. TomTom XXL 540  Screen Replacement: 3 단계, 이미지 1/1
    • Insert the flat head screwdriver into the edge of the device. Using it as a lever, carefully pry the face-plate up.
  4. TomTom XXL 540  Screen Replacement: 4 단계, 이미지 1/1
    • Carefully grab the ribbon cable with two fingers and pull the yellow ribbon cable upwards away from the motherboard.
  5. TomTom XXL 540  Screen Replacement: 5 단계, 이미지 1/1
    • Remove the screen from of the face-plate.
  6. TomTom XXL 540  Screen Replacement: 6 단계, 이미지 1/1
    • Insert the new screen into the face-plate.
  7. TomTom XXL 540  Screen Replacement: 7 단계, 이미지 1/1
    • Reattach the yellow ribbon cable to the motherboard.
  8. TomTom XXL 540  Screen Replacement: 8 단계, 이미지 1/1
    • Using two hands, hold both ends of the device and snap the two plates together.
  9. TomTom XXL 540  Screen Replacement: 9 단계, 이미지 1/1
    • Re-insert the two T5 screws and tighten.
  10. TomTom XXL 540  Screen Replacement: 10 단계, 이미지 1/1
    • Re-apply the label edges back down to cover the screws.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Mike Sollars
회원 가입일: 07/11/13
519 평판
안내서 3개 작성하였습니다
WRI115, Team 1-1, Ruszkiewicz Spring 2013 WRI115, Team 1-1, Ruszkiewicz Spring 2013 회원
WRI115-RUSZKIEWICZ-S13S1G1
4 회원들
안내서 6개 작성하였습니다
댓글 한 개
Hi! Thanks for doing this. How do I release the yellow cable from the board?
Shaun B - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 9
전체 시간: 1,880
