주요 콘텐츠로 건너뛰기
TomTom XXL 540 Battery Replacement
필요한 것
  1. TomTom XXL 540 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Peel back the sticker on the bottom of the device to reveal the two screws.
  2. TomTom XXL 540 Battery Replacement: 2 단계, 이미지 1/1
    • Unscrew the two T5 Torx screws.
  3. TomTom XXL 540 Battery Replacement: 3 단계, 이미지 1/1
    • Wedge the flat head of the screwdriver into the edge of the device. Gently lift the screen from the cover.
  4. TomTom XXL 540 Battery Replacement: 4 단계, 이미지 1/1
    • Release the yellow ribbon cable.
  5. TomTom XXL 540 Battery Replacement: 5 단계, 이미지 1/1
    • Identify the green motherboard. Unscrew the three screws holding the board in place.
  6. TomTom XXL 540 Battery Replacement: 6 단계, 이미지 1/1
    • Remove the motherboard from the back plate.
  7. TomTom XXL 540 Battery Replacement: 7 단계, 이미지 1/1
    • Unplug the battery from the board.
  8. TomTom XXL 540 Battery Replacement: 8 단계, 이미지 1/1
    • Plug the new battery into the white receptacle on the green motherboard.
  9. TomTom XXL 540 Battery Replacement: 9 단계, 이미지 1/1
    • Transfer the green motherboard back into the back plate and secure it with the 3 screws.
  10. TomTom XXL 540 Battery Replacement: 10 단계, 이미지 1/1
    • Reconnect the yellow ribbon cable and connect the screen and back plate back together.
  11. TomTom XXL 540 Battery Replacement: 11 단계, 이미지 1/1
    • Insert the t-5 screws and tighten to secure.
  12. TomTom XXL 540 Battery Replacement: 12 단계, 이미지 1/1
    • Replace the label to cover the screws.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Mike Sollars
회원 가입일: 07/11/13
519 평판
안내서 3개 작성하였습니다
WRI115, Team 1-1, Ruszkiewicz Spring 2013 WRI115, Team 1-1, Ruszkiewicz Spring 2013 회원
WRI115-RUSZKIEWICZ-S13S1G1
4 회원들
안내서 6개 작성하였습니다
댓글 한 개
Very similar for the 4FL60 and 6000, except in :
Step 1 the screws are visible without removing any stickers
Step 4 hint: to release the ribbon, each end of the white bar has a self-sprung clip to ease away, try not to break them. And for the models above there is a small cable plug to unclip
Step 5 there are 5 screws holding the motherboard
Step 6 it is necessary to unclip plugs for the battery and speaker leads
and vice versa for reassembly
Jim Shaw - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 16
전체 시간: 4,646
