주요 콘텐츠로 건너뛰기
TomTom XXL 540 Back Panel Replacement
필요한 것
  1. TomTom XXL 540 Back Panel Replacement, Remove the screws: 1 단계, 이미지 1/2 TomTom XXL 540 Back Panel Replacement, Remove the screws: 1 단계, 이미지 2/2
    • Using tweezers, peel back the sticker on the bottom of the device to reveal the two T5 screws.
    • Use the T5 Torx screwdriver to unscrew the two T5 screws.
  2. TomTom XXL 540 Back Panel Replacement, Remove the faceplate: 2 단계, 이미지 1/1
    • Use a flat edge screwdriver to pry open the faceplate.
  3. TomTom XXL 540 Back Panel Replacement, Remove the ribbon cable: 3 단계, 이미지 1/1
    • Release the ribbon cable that connects the two sides.
  4. TomTom XXL 540 Back Panel Replacement, Remove the screws from the motherboard: 4 단계, 이미지 1/1
    • Identify the green motherboard.
    • Use the T5 Torx screwdriver to unscrew the three T5 screws that hold the motherboard in place.
  5. TomTom XXL 540 Back Panel Replacement, Remove the board and battery: 5 단계, 이미지 1/1
    • Remove and disconnect the motherboard and battery from the back panel.
  6. TomTom XXL 540 Back Panel Replacement, Re-attach the board and battery: 6 단계, 이미지 1/1
    • Attach the motherboard and battery to the new back panel.
결론
Mike Sollars
회원 가입일: 07/11/13
519 평판
안내서 3개 작성하였습니다
WRI115, Team 1-1, Ruszkiewicz Spring 2013 WRI115, Team 1-1, Ruszkiewicz Spring 2013 회원
WRI115-RUSZKIEWICZ-S13S1G1
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 1,308
