주요 콘텐츠로 건너뛰기
Tomado Blender Carbon Brush Replacement
필요한 것
  1. Tomado Blender Carbon Brush Replacement, Carbon Brush: 1 단계, 이미지 1/3 Tomado Blender Carbon Brush Replacement, Carbon Brush: 1 단계, 이미지 2/3 Tomado Blender Carbon Brush Replacement, Carbon Brush: 1 단계, 이미지 3/3
    • Remove the base of the blender by removing the 4 screws at underneath..
  2. Tomado Blender Carbon Brush Replacement: 2 단계, 이미지 1/2 Tomado Blender Carbon Brush Replacement: 2 단계, 이미지 2/2
    • Detach the base however do not separate it too far as it is still attached!
  3. Tomado Blender Carbon Brush Replacement: 3 단계, 이미지 1/3 Tomado Blender Carbon Brush Replacement: 3 단계, 이미지 2/3 Tomado Blender Carbon Brush Replacement: 3 단계, 이미지 3/3
    • Detach any cables/wires from the switch panel. They should be attached with an easy to remove pinch clip (just pinch to unclip).
  4. Tomado Blender Carbon Brush Replacement: 4 단계, 이미지 1/3 Tomado Blender Carbon Brush Replacement: 4 단계, 이미지 2/3 Tomado Blender Carbon Brush Replacement: 4 단계, 이미지 3/3
    • Whilst holding the fan on the inside, unscrew the silicon grip on the top of the blender. This should unscrew with a small amount of force.
  5. Tomado Blender Carbon Brush Replacement: 5 단계, 이미지 1/3 Tomado Blender Carbon Brush Replacement: 5 단계, 이미지 2/3 Tomado Blender Carbon Brush Replacement: 5 단계, 이미지 3/3
    • Unscrew the 3 screws attaching the motor to the top of the case.
  6. Tomado Blender Carbon Brush Replacement: 6 단계, 이미지 1/3 Tomado Blender Carbon Brush Replacement: 6 단계, 이미지 2/3 Tomado Blender Carbon Brush Replacement: 6 단계, 이미지 3/3
    • Unscrew the black box holding the safety switch next to where the motor attaches to the case. You can now remove the motor from the case.
  7. Tomado Blender Carbon Brush Replacement: 7 단계, 이미지 1/3 Tomado Blender Carbon Brush Replacement: 7 단계, 이미지 2/3 Tomado Blender Carbon Brush Replacement: 7 단계, 이미지 3/3
    • Using a soldering iron, heat up the solder attaching the capacitor to the side of the motor. This needs to be repeated on the other side of the motor as there are 2 capacitors (positive and negative).
  8. Tomado Blender Carbon Brush Replacement: 8 단계, 이미지 1/3 Tomado Blender Carbon Brush Replacement: 8 단계, 이미지 2/3 Tomado Blender Carbon Brush Replacement: 8 단계, 이미지 3/3
    • Using a little pressure, insert a 02 Phillips screw driver into the little black slot next to where you desoldered the capacitor. Use this to hold down the clip that keeps it in place.
  9. Tomado Blender Carbon Brush Replacement: 9 단계, 이미지 1/3 Tomado Blender Carbon Brush Replacement: 9 단계, 이미지 2/3 Tomado Blender Carbon Brush Replacement: 9 단계, 이미지 3/3
    • Once you have done this be careful when removing the carbon brushes as it is spring loaded.
  10. Tomado Blender Carbon Brush Replacement: 10 단계, 이미지 1/3 Tomado Blender Carbon Brush Replacement: 10 단계, 이미지 2/3 Tomado Blender Carbon Brush Replacement: 10 단계, 이미지 3/3
    • You can now replace the brushes with new ones and return the clip to its original position. You will need to push the spring back into the slot and this may take some time. Repeat on the other side and your blender should be ready to make smoothie again!
결론
다른 2명이 해당 안내서를 완성하였습니다.
Joel
회원 가입일: 12/05/16
164 평판
안내서 1개 작성함
댓글 한 개
where do you buy new brushes?
alex pelchat - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 18
30일 전: 55
전체 시간: 1,845
