주요 콘텐츠로 건너뛰기
Toniebox Battery Replacement
필요한 것
  1. Toniebox Battery Replacement, Toniebox Opening Procedure: 1 단계, 이미지 2개 중 1개 Toniebox Battery Replacement, Toniebox Opening Procedure: 1 단계, 이미지 2개 중 2개
    • Put the Toniebox on a flat surface (e.g. a desk or a workbench).
    • Apply some pressure and turn the Toniebox counterclockwise to unlock the two clips beneath the bottom plate.
    • You will hear a "klick" when the two clips unlock.
  2. Toniebox Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the bottom plate.
  3. Toniebox Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the Phillips #1 screw on the bottom of the Toniebox.
  4. Toniebox Battery Replacement: 4 단계, 이미지 1개 중 1개
    • Lift the inner part out of the foam housing.
  5. Toniebox Battery Replacement, Battery: 5 단계, 이미지 2개 중 1개 Toniebox Battery Replacement, Battery: 5 단계, 이미지 2개 중 2개
    • Unplug the battery connector from the main board by gently pulling the cables.
    • When reconnecting the new battery make sure to properly orient the connector.
  6. Toniebox Battery Replacement: 6 단계, 이미지 3개 중 1개 Toniebox Battery Replacement: 6 단계, 이미지 3개 중 2개 Toniebox Battery Replacement: 6 단계, 이미지 3개 중 3개
    • Losen the two screws next to the battery. Don't remove them.
    • Lift the main board a bit to widen the gap between the white plastic housing.
    • This gap will help you in the next step.
  7. Toniebox Battery Replacement: 7 단계, 이미지 2개 중 1개 Toniebox Battery Replacement: 7 단계, 이미지 2개 중 2개
    • Feed the battery cable from behind the main board and out of its plastic guide hooks.
    • When installing the new battery you don't have to feed the cable behind the main board. Depending on their length aligning them along the black plastic will suffice.
  8. Toniebox Battery Replacement: 8 단계, 이미지 3개 중 1개 Toniebox Battery Replacement: 8 단계, 이미지 3개 중 2개 Toniebox Battery Replacement: 8 단계, 이미지 3개 중 3개
    • Use a spudger or finger to push down the plastic latch that keeps the battery in place.
    • Push the battery out of its frame.
  9. Toniebox Battery Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the battery.
결론
다른 63명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
de en
100%
Tobias Isakeit님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
Tobias Isakeit
회원 가입일: 03/31/14
129,247 평판
안내서 189개를 작성함
Tobias Isakeit - Repairability Engineer Tobias Isakeit - Repairability Engineer 회원
Business
1 회원
안내서 1,145개를 작성함
17가이드 댓글
Hallo,
habe den Akku (30€ über eBay
Kerem - 답글
Hi kann mir einer sagen ob der Akku denn man im ifixit Shop kaufen kann ein ni-mh Akku ist?
Alexander - 답글
Jep, es handelt sich um einen NiMH Akku (ist auf dem Produktbild zu sehen). Wie der originale, und sogar mit etwas mehr Ladung ;)
Tobias Isakeit -
Und ist es besser einen mit mehr Ladung zu nehmen oder sollte man es so wie im Original nutzen? Was ist in dem Original Akku der Tonie Box? 1800mAh?
yvi14 - 답글
Der originale hat 2000 mAh, der in unserem Store hat 2200 mAh. Hält einfach ein wenig länger ;)
Tobias Isakeit -
댓글 쓰기
조회 통계:
지난 24시간: 158
지난 7일: 1,067
지난 30일: 4,487
전체 시간: 140,222
