주요 콘텐츠로 건너뛰기
Tonneau Trifold Bed Cover Retention Pin Replacement
필요한 것
  1. Tonneau Trifold Bed Cover Retention Pin Replacement, Retention Pin: 1 단계, 이미지 3개 중 1개 Tonneau Trifold Bed Cover Retention Pin Replacement, Retention Pin: 1 단계, 이미지 3개 중 2개 Tonneau Trifold Bed Cover Retention Pin Replacement, Retention Pin: 1 단계, 이미지 3개 중 3개
    • Locate the two screws on the retaining latch.
    • Use an Allen Wrench to loosen the screws.
    • The screws are tight and may require significant force.
  2. Tonneau Trifold Bed Cover Retention Pin Replacement: 2 단계, 이미지 2개 중 1개 Tonneau Trifold Bed Cover Retention Pin Replacement: 2 단계, 이미지 2개 중 2개
    • Continue loosening the screws until they are both loose enough to remove by hand.
  3. Tonneau Trifold Bed Cover Retention Pin Replacement: 3 단계, 이미지 3개 중 1개 Tonneau Trifold Bed Cover Retention Pin Replacement: 3 단계, 이미지 3개 중 2개 Tonneau Trifold Bed Cover Retention Pin Replacement: 3 단계, 이미지 3개 중 3개
    • Grab both screws and pull them straight out.
    • Line up the holes on the replacement latch, then insert the new screws.
  4. Tonneau Trifold Bed Cover Retention Pin Replacement: 4 단계, 이미지 3개 중 1개 Tonneau Trifold Bed Cover Retention Pin Replacement: 4 단계, 이미지 3개 중 2개 Tonneau Trifold Bed Cover Retention Pin Replacement: 4 단계, 이미지 3개 중 3개
    • Hand tighten both of the bolts onto the new latch.
  5. Tonneau Trifold Bed Cover Retention Pin Replacement: 5 단계, 이미지 2개 중 1개 Tonneau Trifold Bed Cover Retention Pin Replacement: 5 단계, 이미지 2개 중 2개
    • Tighten both screws evenly until the latch is held firmly in place.
    • Do not over tighten - you could break the Allen Wrench or strip the screws!
결론
To reassemble your device, follow these instructions in order.
작성자
8다른 기여자 명과 함께
Christopher King
회원 가입일: 01/16/18
139 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 11
전체 시간: 964
