주요 콘텐츠로 건너뛰기
Toolcraft ST-50D solder station Disassembly
필요한 것
  1. Toolcraft ST-50D solder station Disassembly, So looks the solder station.: 1 단계, 이미지 1/1
    • I think you can disassembly other models of Toolcraft ST solder stations 50/80/100 analog or digital the same way.
  2. Toolcraft ST-50D solder station Disassembly, Put the solder station on the back.: 2 단계, 이미지 1/1
    • There are two holes with screws on the bottom side (green circles on the picture) and the 2-nd pair of screws is under the two rubbery "legs" (red circles).
  3. Toolcraft ST-50D solder station Disassembly, Unglue the two "legs"...: 3 단계, 이미지 1/1
    • ... by nails or by flat screwdriver and you will see the second pair of holes with screws.
  4. Toolcraft ST-50D solder station Disassembly, Unscrew the screws ...: 4 단계, 이미지 1/1
    • ... by Phillips #1 screwdriver and you can open the body of the solder station.
  5. Toolcraft ST-50D solder station Disassembly: 5 단계, 이미지 1/1
    • The cables connected to switch: ON is Up , from inside: 1) RED + BLUE 2) BROWN
  6. Toolcraft ST-50D solder station Disassembly: 6 단계, 이미지 1/1
    • From inside.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Martin Kubica
회원 가입일: 05/13/16
784 평판
안내서 1개 작성함
댓글 4개
Hi! Unfortunately, I have stupidly pulled off the contact sockets of the switch when disassembling my station. But I did not notice how they were originally connected. Could you please take a look and maybe take a picture of how the contacts are connected to the switch? I thank you in advance.
omanoman - 답글
Hi.
So I added a picture of cables connected to the switch. ON position of the switch is Up, the cables are from inside of the solder station.
Martin Kubica
Martin Kubica - 답글
Hello Martin, really appreciate your guide but do you have a photo of the back of the board with all the connections? I took it apart but did not take note of which connector the White, Blue and Red/Black wires went to. Its not clear on the photos above, would be hugely appreciated. Thanks!
Michael Telatynski - 답글
здравствуйте помагите найти на нее нагревательный элементяя даже не знаю какой должен быть спасибо
Павел Vor - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 26
전체 시간: 1,683
