주요 콘텐츠로 건너뛰기
Top Fin 20gal Filter Replacement
필요한 것
  1. Top Fin 20gal Filter Replacement, Filter cartridge: 1 단계, 이미지 1/2 Top Fin 20gal Filter Replacement, Filter cartridge: 1 단계, 이미지 2/2
    • Make sure the filter is turned off!
    • Unplug the filter.
  2. Top Fin 20gal Filter Replacement: 2 단계, 이미지 1/2 Top Fin 20gal Filter Replacement: 2 단계, 이미지 2/2
    • Remove the filter lid by pushing it up with both hands.
  3. Top Fin 20gal Filter Replacement: 3 단계, 이미지 1/2 Top Fin 20gal Filter Replacement: 3 단계, 이미지 2/2
    • Pull the old filter cartridge out of the filter.
    • Dispose of it in the garbage afterwards.
  4. Top Fin 20gal Filter Replacement: 4 단계, 이미지 1/1
    • Rinse the new filter cartridge with cold water.
    • Cold water removes dust in the filter cartridge.
  5. Top Fin 20gal Filter Replacement: 5 단계, 이미지 1/3 Top Fin 20gal Filter Replacement: 5 단계, 이미지 2/3 Top Fin 20gal Filter Replacement: 5 단계, 이미지 3/3
    • Insert the filter cartridge replacement into the filter slot.
  6. Top Fin 20gal Filter Replacement: 6 단계, 이미지 1/2 Top Fin 20gal Filter Replacement: 6 단계, 이미지 2/2
    • Pour water into the filter using a small bucket of water.
    • At least half a bucket of water is sufficient.
  7. Top Fin 20gal Filter Replacement: 7 단계, 이미지 1/2 Top Fin 20gal Filter Replacement: 7 단계, 이미지 2/2
    • Put the lid back on.
    • Ensure a click sound is made to secure the lid.
  8. Top Fin 20gal Filter Replacement: 8 단계, 이미지 1/2 Top Fin 20gal Filter Replacement: 8 단계, 이미지 2/2
    • Plug in the filter.
결론
The filter should power on and water flows through the filter.
Rohme Cabacungan
회원 가입일: 09/09/21
157 평판
안내서 1개 작성함
York University, Team 2-5, O'Regan Fall 2021 York University, Team 2-5, O'Regan Fall 2021 회원
YORK-O'REGAN-F21S2G5
1 회원
안내서 1개 작성하였습니다
댓글 한 개
You guys are awesome and have guides out in everything. My many thanks to all the ifixit staff and reverse engineering minds.
DeCon ReCon - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 28
30일 전: 164
전체 시간: 13,552
