주요 콘텐츠로 건너뛰기
Engage Wired Optical Mouse Top and Outer Shell Removal
필요한 것
  1. Engage Wired Optical Mouse Top and Outer Shell Removal, Engage Wired Optical Mouse Top and Outer Shell Removal: 1 단계, 이미지 1/1
    • Flip the mouse over and peel off the stickers on the perimeter of the bottom of the mouse.
  2. Engage Wired Optical Mouse Top and Outer Shell Removal: 2 단계, 이미지 1/1
    • Use the Phillips #1 screwdriver to remove four 5 mm screws from the bottom of the mouse.
    • Use the Phillips #1 screwdriver to remove the two 9 mm screws from the bottom of the mouse.
  3. Engage Wired Optical Mouse Top and Outer Shell Removal: 3 단계, 이미지 1/3 Engage Wired Optical Mouse Top and Outer Shell Removal: 3 단계, 이미지 2/3 Engage Wired Optical Mouse Top and Outer Shell Removal: 3 단계, 이미지 3/3
    • Grab the top shell of the mouse and lift up to remove.
  4. Engage Wired Optical Mouse Top and Outer Shell Removal: 4 단계, 이미지 1/1
    • The capacitors on this board can release stored electrical energy if touched.
    • Touch your capacitor discharge tool to the capacitor leads on the board to release the stored energy. If leads are inaccessible, wait until you've removed the board from the mouse body.
  5. Engage Wired Optical Mouse Top and Outer Shell Removal: 5 단계, 이미지 1/2 Engage Wired Optical Mouse Top and Outer Shell Removal: 5 단계, 이미지 2/2
    • Use a spudger to pry underneath the white plug and pop it out to disconnect the upper board from the lower board.
결론
다른 2명이 해당 안내서를 완성하였습니다.
royceeklund
회원 가입일: 01/18/13
79 평판
안내서 3개 작성하였습니다
Cal Poly, Team 18-36, Regan Winter 2013 Cal Poly, Team 18-36, Regan Winter 2013 회원
CPSU-REGAN-W13S18G36
3 회원들
안내서 30개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 14
30일 전: 30
전체 시간: 3,423
