주요 콘텐츠로 건너뛰기
Toro Lawn Mower Cutting Blade Replacement
필요한 것
  1. Toro Lawn Mower Cutting Blade Replacement, Cutting Blade: 1 단계, 이미지 1/1
    • Disconnect the spark plug to ensure that the lawn mower does not accidentally turn over and cause the mower to turn on.
  2. Toro Lawn Mower Cutting Blade Replacement: 2 단계, 이미지 1/1
    • Flip the mower onto its side exposing the blade and under carriage.
  3. Toro Lawn Mower Cutting Blade Replacement: 3 단계, 이미지 1/1
    • Place wood in between the blade and the wall of the mower to ensure that the blade does not move while you are tightening or loosening the bolt.
  4. Toro Lawn Mower Cutting Blade Replacement: 4 단계, 이미지 1/1
    • Using the 5/8 wrench, turn the blade counter clockwise until the bolt is loose then pull the blade off.
    • Make sure that safety gloves are worn at all times when handling the new or old cutting blade.
  5. Toro Lawn Mower Cutting Blade Replacement: 5 단계, 이미지 1/1
    • Place the new blade in right side up into the bracket and line up the bolt.
    • Make sure that safety gloves are being worn at all times when handling either the new or old cutting blade.
  6. Toro Lawn Mower Cutting Blade Replacement: 6 단계, 이미지 1/1
    • Using the 5/8 ratchet, turn the bolt clockwise until the bolt does not turn anymore.
  7. Toro Lawn Mower Cutting Blade Replacement: 7 단계, 이미지 1/1
    • Flip the mower right-side up and reconnect the spark plug.
결론
This simple fix should help make the lawn mower function efficiently and safely for years to come.
다른 3명이 해당 안내서를 완성하였습니다.
Colter Batterton
회원 가입일: 09/25/18
199 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 7
7일 전: 136
30일 전: 407
전체 시간: 4,315
