주요 콘텐츠로 건너뛰기
Toro Walk Behind Mowers 21199HD 2018 Brake Cable Replacement
필요한 것
  1. Toro Walk Behind Mowers 21199HD 2018 Brake Cable Replacement, Disconnect the spark plug wire: 1 단계, 이미지 2개 중 1개 Toro Walk Behind Mowers 21199HD 2018 Brake Cable Replacement, Disconnect the spark plug wire: 1 단계, 이미지 2개 중 2개
    • Before you begin, ensure that the mower is powered down and cool to the touch.
    • Grab the plastic housing at the end of the spark plug wire and pull firmly to disconnect it.
  2. Toro Walk Behind Mowers 21199HD 2018 Brake Cable Replacement, Chock the rear wheels: 2 단계, 이미지 1개 중 1개
    • Chock the rear wheels to prevent the mower from rolling during service.
    • If the blades are extremely dirty, you can clean them using the washout fitting so the bolts on the underside of the blade guard are accessible.
  3. Toro Walk Behind Mowers 21199HD 2018 Brake Cable Replacement, Lift up the deflector: 3 단계, 이미지 2개 중 1개 Toro Walk Behind Mowers 21199HD 2018 Brake Cable Replacement, Lift up the deflector: 3 단계, 이미지 2개 중 2개
    • Lift up the plastic deflector.
  4. Toro Walk Behind Mowers 21199HD 2018 Brake Cable Replacement, Remove the grass bag: 4 단계, 이미지 3개 중 1개 Toro Walk Behind Mowers 21199HD 2018 Brake Cable Replacement, Remove the grass bag: 4 단계, 이미지 3개 중 2개 Toro Walk Behind Mowers 21199HD 2018 Brake Cable Replacement, Remove the grass bag: 4 단계, 이미지 3개 중 3개
    • While holding the deflector up and out of the way, lift the grass bag handle away from the mower to detach it.
    • Remove the grass bag.
  5. Toro Walk Behind Mowers 21199HD 2018 Brake Cable Replacement, Cut the zip tie: 5 단계, 이미지 3개 중 1개 Toro Walk Behind Mowers 21199HD 2018 Brake Cable Replacement, Cut the zip tie: 5 단계, 이미지 3개 중 2개 Toro Walk Behind Mowers 21199HD 2018 Brake Cable Replacement, Cut the zip tie: 5 단계, 이미지 3개 중 3개
    • Cut and remove the zip tie holding the cables together near the base of the handle.
    • During reassembly, replace this zip tie.
  6. Toro Walk Behind Mowers 21199HD 2018 Brake Cable Replacement, Remove the cable guides: 6 단계, 이미지 2개 중 1개 Toro Walk Behind Mowers 21199HD 2018 Brake Cable Replacement, Remove the cable guides: 6 단계, 이미지 2개 중 2개
    • Use your fingers and press up from the bottom to remove the plastic cable guide from the handle.
  7. Toro Walk Behind Mowers 21199HD 2018 Brake Cable Replacement: 7 단계, 이미지 3개 중 1개 Toro Walk Behind Mowers 21199HD 2018 Brake Cable Replacement: 7 단계, 이미지 3개 중 2개 Toro Walk Behind Mowers 21199HD 2018 Brake Cable Replacement: 7 단계, 이미지 3개 중 3개
    • Spread the cable guide apart and remove it from the cables.
  8. Toro Walk Behind Mowers 21199HD 2018 Brake Cable Replacement: 8 단계, 이미지 2개 중 1개 Toro Walk Behind Mowers 21199HD 2018 Brake Cable Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the black silicone cap covering the nut on the kill switch and upper cable guide assembly.
  9. Toro Walk Behind Mowers 21199HD 2018 Brake Cable Replacement: 9 단계, 이미지 1개 중 1개
    • Use a 7/16 inch socket or wrench to remove the nut securing the kill switch and upper cable guide assembly.
  10. Toro Walk Behind Mowers 21199HD 2018 Brake Cable Replacement: 10 단계, 이미지 3개 중 1개 Toro Walk Behind Mowers 21199HD 2018 Brake Cable Replacement: 10 단계, 이미지 3개 중 2개 Toro Walk Behind Mowers 21199HD 2018 Brake Cable Replacement: 10 단계, 이미지 3개 중 3개
    • Unclip and remove the upper cable guide from the handle.
    • Unroute the cables from the cable guide.
  11. Toro Walk Behind Mowers 21199HD 2018 Brake Cable Replacement, Detach the retainer arm: 11 단계, 이미지 3개 중 1개 Toro Walk Behind Mowers 21199HD 2018 Brake Cable Replacement, Detach the retainer arm: 11 단계, 이미지 3개 중 2개 Toro Walk Behind Mowers 21199HD 2018 Brake Cable Replacement, Detach the retainer arm: 11 단계, 이미지 3개 중 3개
    • Rotate the cable retainer arm 90˚ upwards, perpendicular to the handle, to unlock it.
    • Pull the arm away from the handle to remove it.
  12. Toro Walk Behind Mowers 21199HD 2018 Brake Cable Replacement, Remove the cable from the brake handle: 12 단계, 이미지 3개 중 1개 Toro Walk Behind Mowers 21199HD 2018 Brake Cable Replacement, Remove the cable from the brake handle: 12 단계, 이미지 3개 중 2개 Toro Walk Behind Mowers 21199HD 2018 Brake Cable Replacement, Remove the cable from the brake handle: 12 단계, 이미지 3개 중 3개
    • Use a flathead screwdriver to pry off the single-use cap locking the brake cable to the brake handle.
    • During reassembly, replace this single-use cap.
  13. Toro Walk Behind Mowers 21199HD 2018 Brake Cable Replacement: 13 단계, 이미지 2개 중 1개 Toro Walk Behind Mowers 21199HD 2018 Brake Cable Replacement: 13 단계, 이미지 2개 중 2개
    • Remove the brake cable from the brake handle.
  14. Toro Walk Behind Mowers 21199HD 2018 Brake Cable Replacement, Remove the guide plates: 14 단계, 이미지 1개 중 1개
    • Use a 3/8 inch socket to remove the cable guide plate screw.
  15. Toro Walk Behind Mowers 21199HD 2018 Brake Cable Replacement: 15 단계, 이미지 2개 중 1개 Toro Walk Behind Mowers 21199HD 2018 Brake Cable Replacement: 15 단계, 이미지 2개 중 2개
    • Remove the cable guide plate.
  16. Toro Walk Behind Mowers 21199HD 2018 Brake Cable Replacement: 16 단계, 이미지 1개 중 1개
  17. Toro Walk Behind Mowers 21199HD 2018 Brake Cable Replacement: 17 단계, 이미지 3개 중 1개 Toro Walk Behind Mowers 21199HD 2018 Brake Cable Replacement: 17 단계, 이미지 3개 중 2개 Toro Walk Behind Mowers 21199HD 2018 Brake Cable Replacement: 17 단계, 이미지 3개 중 3개
    • Lift the cable out of the groove in the frame.
  18. Toro Walk Behind Mowers 21199HD 2018 Brake Cable Replacement, Find the end of the brake cable: 18 단계, 이미지 3개 중 1개 Toro Walk Behind Mowers 21199HD 2018 Brake Cable Replacement, Find the end of the brake cable: 18 단계, 이미지 3개 중 2개 Toro Walk Behind Mowers 21199HD 2018 Brake Cable Replacement, Find the end of the brake cable: 18 단계, 이미지 3개 중 3개
    • Before tilting the mower, drain the gas tank.
    • Tilt the mower onto its side, propping the handle up with a block of wood.
    • Locate the end of the brake cable underneath the mower, in front of the driveline, and above the blade guard.
    • The end of the brake cable is attached to a spring, and they come out as one unit.
    • The spring is hooked to a shiny U-shaped post.
  19. Toro Walk Behind Mowers 21199HD 2018 Brake Cable Replacement, Remove the brake cable: 19 단계, 이미지 3개 중 1개 Toro Walk Behind Mowers 21199HD 2018 Brake Cable Replacement, Remove the brake cable: 19 단계, 이미지 3개 중 2개 Toro Walk Behind Mowers 21199HD 2018 Brake Cable Replacement, Remove the brake cable: 19 단계, 이미지 3개 중 3개
    • Reach into the underside of the mower and grab the spring at the end of the brake cable.
    • Slide the spring towards the open end of the U-shaped post.
    • This can be a difficult area to see and reach. Use a flashlight if need be.
  20. Toro Walk Behind Mowers 21199HD 2018 Brake Cable Replacement: 20 단계, 이미지 3개 중 1개 Toro Walk Behind Mowers 21199HD 2018 Brake Cable Replacement: 20 단계, 이미지 3개 중 2개 Toro Walk Behind Mowers 21199HD 2018 Brake Cable Replacement: 20 단계, 이미지 3개 중 3개
    • Remove the spring from the U-shaped post.
    • Once unhooked, you can flip the mower back onto its wheels.
  21. Toro Walk Behind Mowers 21199HD 2018 Brake Cable Replacement: 21 단계, 이미지 3개 중 1개 Toro Walk Behind Mowers 21199HD 2018 Brake Cable Replacement: 21 단계, 이미지 3개 중 2개 Toro Walk Behind Mowers 21199HD 2018 Brake Cable Replacement: 21 단계, 이미지 3개 중 3개
    • Remove the brake cable assembly.
    • During reassembly, ensure the cable has adequate slack and operates as expected before tightening the bolts on the cable guides.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Carsten Frauenheim
회원 가입일: 03/10/20
155,981 평판
안내서 439개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,788개를 작성함
1가이드 댓글
Unless I missed it, I think there should be a note to remind people to drain the gas tank before tipping the unit on its side. It may be common sense for a lot of people familiar with small engines, but not everyone (me) may think or know to do this. I just assumed that it would be fine to tip on its side without modification, and had to do some minor repair work after finding out that that was not the case. The guide was otherwise great for this repair and it was successful!
ELIZABETH - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 8
지난 30일: 22
전체 시간: 1,718
